| by MAC | January 28, 2009 | ||
| Test Setup & Methodologies Test Setup & Methodologies ![]() Test Platform: ![]() Testing will occur on a Highspeed PC Standard Top Deck Tech Station, and not in a traditional case. This allows easier access to the motherboard for the constant poking and prodding that is required during the reviewing process. The setup remained as pictured during the duration of the benchmarking and stability overclocking process. Overclocking MethodologyAlthough the F3-12800CL9T-6GBNQ is not marketed as a hardcore-overclocking product, we still anticipate some solid results from this first-generation low voltage triple-channel DDR3 memory kit, and we are definitely going to find out what it is truly capable of. The overclocking section is the part of our reviews that we take the most pride in, and we spend an excessive number of hours testing, tweaking, failing, and succeeding in order to give you the best possible insight into each product's overclocking capabilities. After all, if you are anything like us, the overclocking section is the first (and often last!) part that you read when checking out a product review. For the purposes of this review, our overclocking efforts will primarily focus on four different timings configurations (7-7-7/8-8-8/9-9-9/10-10-10) and three different voltage settings (1.55V-1.65V-1.75V). The CPU frequency will be kept as close as possible to the stock 3200Mhz, while the Uncore and QPI Link near 3200Mhz and 6400Mhz, respectively. Due multiplier limitations, when running at DDR3-1866 10-10-10 the lowest selectable Uncore/Integrated Memory Controller (IMC) speed is 3733Mhz, so that is what we used throughout our testing. The QPI/DRAM voltage was kept at a relatively high 1.45V throughout our tests, in order to ensure (as best as possible) that the integrated memory controller would not be a bottleneck. During our overclocking adventures we put an emphasis on stability. While the question “What is stable?” could be debated endlessly, we have devised a methodology that combines a wide range of programs that test the stability of the entire system. Here is the suite of applications that will be run in order to validate each of the overclocks:
Altogether, the above suite should provide enough stress testing to ensure a completely stable overclock, however we are always up for new suggestions. As always, no two systems are ever alike, so your results may vary. Also, overclock at your own risk! The Core i7 platform is brand new, and if you try to mimic our results there is always the possibility that you could damage any and all of your components. If you aren’t fully confident in what you are doing, feel free to stop by our forums and our helpful community will be glad to offer some assistance. ![]() Benchmark MethodologyFor this review, our benchmarking section will focus solely on the G.Skill kit, in stock and overclocked configurations. The reasoning behind this approach is that there is an infinitesimal clock-for-clock performance difference between two memory kits that are equally-clocked and with identical timings, thus declaring one product a winner based on a 1% performance advantages seems pointless to us. Since the Core i7 platform and triple-channel memory kits are quite new, we have decided to test the memory at various clock speeds and timings in order to demonstrate the effect they have on overall system performance. ![]() We have outlined the four setups in the sample graph above. The blue results will indicate the performance at the XMP default timings. The only changes that will be made are to the memory multiplier and timings in order to get it running at the desired frequency and timings. Every other setting will be at the defaults that the BIOS sets. These overclock results are again, the best overall overclock we could manage with this motherboard and the hardware used in the review. As was mentioned in the overclocking section, we used Everest bandwidth benchmarks and a few other performance tests to determine which settings were ultimately faster, not just higher. For all of the benchmarks, appropriate lengths are taken to ensure an equal comparison through methodical setup, installation, and testing. The following outlines our testing methodology: A) Windows is installed using a full format. B) Intel Chipset drivers and accessory hardware drivers (audio, network, GPU) are installed followed by a defragment and a reboot. C) Programs and games are then installed followed by another defragment. D) Windows updates are then completed installing all available updates followed by a defragment. E) Benchmarks are each ran three times after a clean reboot for every iteration of the benchmark unless otherwise stated, the results are then averaged. We have listed the benchmark versions on each graph as results can vary between updates. That is about all you need to know methodology wise, so let's see what kind of numbers this memory kit has achieved in our overclocking section and in our benchmarking suite. | ||
| Latest Reviews in RAM | |||||||||
