Categories
Review Contents:
Hardware Canucks: Benchmarkers Guide to the Phenom II
by 3oh6     |     January 8, 2009
Moving forward from our air cooling results on to the more exciting aspect of this journey, we turn the cooling position over to a tired old Chilly1 single stage phase change cooler that requires a re-gas and re-tune very badly. The heat output of these new quad core processors when heavily overclocked is no match for this phase change but we will do our best with it anyway.
For those that don't know, a phase change cooler uses a compressor to compress a gas into a liquid that is very cold because it is compressed. This liquid is then fed into a small evaporator that makes direct contact with the processor and cooling it in the process. Phase change coolers can be bought retail from companies like Asetek with their VapoChill and Prometia with their Mach II/GTs. The Chilly1 phase change we are using is a privately built unit that would be very much comparable to a VapoChill phase change in its current state. We will start with some photos of the unit and the move on to the insulation that is required and finally some photos of the setup during testing.
For those familiar with phase change cooling, there is nothing too spectacular about our unit. It is very basic with just an on/off switch and no control software. It is not designed for 24/7 use and simply used for benching. It was initially tuned for 65nm dual core loads so desperately needs to be tuned for the higher output quad core processors of today. Even still, it should keep temperatures below -20C under load we figure on this Phenom II and that should be plenty to squeeze a good pinch more out of the processor from our air results. As mentioned though, before we get into any sub-zero temperatures, we need to insulate. Preventing condensation from forming is the key to any sub-zero computing.
To be truthfully honest, it took us about four and a half minutes to go from a bare board to a fully insulated setup. Aside from the single capacitor towards the top edge of the motherboard and the socket, no other cut outs are necessary. A simple rectangle armaflex layer with the PWM capacitors cut out is all this board really needs. We also put a small piece of armaflex tape over the cam end of the socket to ensure a complete seal against the CPU integrated heat spreader since the armaflex layer doesn't cover it. The entire motherboard back side is insulated in our test bench setup so absolutely no warm air will be near the underside of the motherboard causing condensation. Overall we are quite confident that this insulation job will be 100% adequate to do its job, despite the absolute minimum amount of time it took to setup. It isn't often these days that insulating is this easy but it certainly won't get any easier than the GA-MA790GP-DS4H. We will now finish off with a couple photos of the setup in action.
Our setup today is pretty straight forward and simple, aside from the phase cooler slapped on the CPU. As we can see though there is nothing really fancy with this setup, and only a couple fans providing the cooling for the stock motherboard. It seems about the time that we looked at some numbers and saw what this processor can do at sub-zero temperatures. We will start with the less demanding benchmarks and work our way down to tougher, multi-core, benches.
CPU-Z Validation
click for full size...
CPU-Z Validation
Hexus PiFast
Super Pi 1M
Super Pi 32M
WPrime - 32M
WPrime - 1024M
Aquamark 3
3DMark 01
3DMark 03
3DMark 05
3DMark 06
3DMark Vantage - Performance w/o PhysX
Going from our air cooled results, these numbers are good but not jaw dropping. The strength of the phase change unit accepts the primary blame and shows this when going to multi-core benchmarks. The heat load produced at these voltages with these elevated frequencies is just too much for this phase setup. The WPrime results are the most telling with the difference between WPrime 32M and WPrime1024M being 437MHz. This is because temperatures raise so much after a minute or two of four cores under load. Any more vCORE and wPrime 1024M was into positive temperatures rather quickly. The 3DMark results from 01, 03, 05, and AM3 are again quite nice because they are single core benchmarks that allow the phase change to maintain temperatures of -30C under load. 3DMark 06 faired the best of the multi-core benchmarks but Vantage did quite poorly only being able to squeeze out a run at 4256MHz.
The vCORE we imposed for these phase results was 1.70v set in the BIOS. Some of the multi-core benchmarks needed that voltage to be lowered to run stable as heat was causing issues. We have mentioned a couple times that the phase setup we have was idling at -50C and up to that temperature, this system behaved beautifully. We were able to clock the HT and HTT buses without issue or complaint. There are a lot of reports that these chips won't be able to clock either once we go sub-zero but up to this point, our sample seems to be just fine. Let's now see what happens when temperatures are no longer an issue with LN2 on tap.
Latest Reviews in Processors
January 4, 2010
In recent years, Intel used Nehalem architecture to push both a high end platform with their Bloomfield-based CPUs and their newly released Lynnfield generation of LGA1156 chips. Today they reveal th...
September 7, 2009
After countless previews, leaked benchmarks and general, all-round excitement, Lynnfield processors are finally here and will be launched to the public. Naturally, with widespead availability comes r...
June 9, 2009
Summer is here and with it comes vacation and the classical road trips people seem to either love or hate. Before your own vacation rears its head, we want to take you on a trip you will not soon forg...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/13562-hardware-canucks-benchmarkers-guide-phenom-ii.html
Posted By Date
Overclocking the AMD Phenom II at -30ーC Icrontic Tech January 8, 2010 09:00 PM
GIGABYTE GA-MA770-UD3 AM2+/AM3 Motherboard Review | Reviews Zone | Digital Cameras | Cell Phones | Laptops | PC | IPhone | Devices | Hardware August 14, 2009 12:10 PM
AMD Athlon総合 (AM2&AM3) その88 August 10, 2009 06:12 AM
*** Official Phenom 2 Review Thread *** - Computer Forums July 10, 2009 03:52 AM
Informacije, testiranja i recenzije Athlon II i Phenom II serije procesora - Stranica 4 - PC Ekspert Forum July 8, 2009 07:24 AM
PHENOM II Reviews - [H]ard|Forum June 19, 2009 01:54 PM
NextGPU June 5, 2009 08:50 PM
Hardware - : Phenom II X4 920 Phenom II X4 940 BE Socket AM2+ | Overclockers.com.ua May 30, 2009 02:06 PM
AMD Shanghai/Deneb Review Thread - Page 50 - XtremeSystems Forums May 16, 2009 04:05 AM
Phenom II incelemeleri (19 adres) May 11, 2009 05:02 PM
Chasing the dragon - The Inquirer May 11, 2009 05:55 AM
Review Roundup: Phenom II May 5, 2009 06:01 AM
View topic - List of AMD Deneb Reviews April 22, 2009 08:32 AM
AMD Shanghai/Deneb Review Thread - XtremeSystems Forums April 12, 2009 07:13 AM
Lancement du Phenom 2 : r馗apitulatif des tests - G駭駻ation 3D April 9, 2009 04:58 AM
[Multiple]Phenom 940 review - Overclock.net - Overclocking.net April 8, 2009 08:54 AM
Icrontic Overclocking the AMD Phenom II at -30ーC April 3, 2009 10:21 PM
Phenom II X4 940 is compared to which Intel Quad CPU? - www.hardwarezone.com.sg April 3, 2009 03:55 AM
AMD Phenom II X4 Review Thread - Page 5 - nV News Forums April 3, 2009 01:11 AM
