| by AkG | January 11, 2009 | ||
| Conclusion ConclusionWell this certainly is an interesting piece of kit now isn’t it? Basically, the Domino was able to achieve everything we hoped it would and then some. Its ability to change noise characteristics with a simple push of button is certainly innovative; and more importantly it “Just Works”. Heck, I wish the Freezone Elite or the Boreas came with this option as it really does bridge the gap between total reliance on the basic “stock” settings and the complete tweakability of the MTEC control unit and its accompanying software. The only problem with this setup versus software is the fact you need access to the interior of your case to adjust settings. When it comes to performance the Domino is actually quite good when compared to its immediate competition in the pre-built, closed loop category. It soundly beats the LCLC when set to high speed but tends to suffer when the Performance option is selected. It is also not able to keep up with high end air cooling but when you look at the sub-$100 asking price of the Domino you will begin wondering why you never went with water cooling before. That being said, when you increase the fan speed, things start looking alot better even though this is accompanied by a slight increase in noise. This noise increase is a small price to pay especially when you consider the majority of GPU fans product far more noise when the cores they are cooling are under high loads. This unit is not only innovative in its approach to noise configurations but its built-in LCD really does push this unit from “good’ to “great”. If you have a windowed case (and this bad boy really does cry out for one) you will be treated to a veritable cornucopia of information. If you are like us your computer sits on the desk right next to you and your monitor so all the information that you need to know about your Domino (and CPU) is simple a glance away. Unfortunately, if you don't have a window on your case, all of this will be completely lost on you. OK now that we have gone through a few of the good things about the Domino, we should mention that no all is wine and roses. The innovative 3 setting switch does feel a little heavy handed when compared to the MTEC’s near unlimited tweakability. It’s a heck of a lot better than nothing but it’s like going from a 6 speed manual to a 3 speed automatic; sure the automatic is easy and covers a wide band of usability but you can’t get under the hood and get all the capabilities that this cooler has. Where the Domino has been shrunk like it was left out in the sun too long we really wish CoolIT had taken some of this space and doubled up on the thickness of the rad. The built in radiator is only a 120mm single row, single flow design and while it gives great performance for the price, we really wish it was a 120mm dual row, dual pass design like the Thermochill PA120.1 or Feser One X-120 TFC XChanger. This really would take the Domino from a great beginner's water-cooling loop and make into a great compact water cooling aficionado system. Would this add significantly to the Domino’s cost? It certainly would add a nice few dollars onto the build cost, but I for one would certainly consider it worthwhile. It would also bridge the (now obvious) gap between CoolIT starter lineup (PURE and Domino) and their intermediate line (Freezone Elite). Honestly, that is about all we can complain about when it comes to the Domino. In the end we could go on and on about how compact the Domino is, or how it comes with the most elegant information system we have seen in a prebuilt WC loop; or even how it comes ready for 1366 systems. All of this is best summed up by saying the Domino is quite innovative while being a very good value if you want to get you feet wet with water cooling. Honestly, if CoolIT ever manages to tweak this unit and allow it to fulfill the potential we see in it and sell it for less than a hundred and twenty dollars you would be looking at the perfect trifecta of HWC awards (Dam Good, Dam Good Value AND Dam Innovative). In the mean time, I’m jealous over that LCD not being on my beloved Freezone Elite and all of us here at HWC would like to extend our congratulations to CoolIT on knocking another one clear out of the park. Pros: - Customizable - Audible alarms - Built in LCD - Compact - 1336 mounting plate included - Good cooling performance - Great price Cons: - Controller “only” has three settings - Controller really needs MTEC like tweakability - What’s up with that name!? It deserves a more visceral name in keeping with its power and flexibility. - Less than optimal retaining screws (I.E. minor Installation issues) - Wish Freezone Elite had that LCD! | ||
