Categories
Review Contents:
EVGA X58 SLI LGA 1366 Motherboard Review
by 3oh6     |     January 5, 2009
Heat & Acoustical Testing
The heat and acoustical testing normally concentrates on the north bridge and its cooling solutions. With the north bridge playing a smaller role in the X58 game, we decided to us this section to really look at the PWM cooling of the EVGA X58 SLI. We also found out that the NB temperature sensor does not actually report the NB temperature in Windows, only the BIOS. This means there is no accurate way for measuring temperatures of the NB right now, EVGA is working on a BIOS option to enable NB temp reading in Windows, which made the PWM focus a no brainer for us.
With heafty power hungry i7 quad core CPUs populating the LGA1366 socket, the PWM area of the motherboard is put under great stress. Because of this there is a substantial amount of heat being generated and despite the large heat sink EVGA has gone with on these components, the PWM temperatures are still rather high. Let's first look at exactly what we are dealing with.
The PWM MOSFET heat sink is a fairly simple design that looks a lot more elaborate than it is. There is a single long heat pipe that runs the length of the MOSFETs and then angles up on each end to connect with the cooling fins that dissipate the heat generated by the components it sits on. Again, this is very simple but seemingly effective. The best part of this design is that it is seperate from the NB/SB heat sink and swapping it out for water cooling or another air cooling solution only requires it to be removed. This is what we are looking at with the heat sink removed:
The MOSFETs used by EVGA on this X58 SLI are not your standard D-Pack surface mount MOSFETs. Instead, EVGA has used a high efficiency Renesas R2J20602 56-pin leadless QFN package MOSFET. These integrated driver-MOSFETs provide low voltage stability and switching frequencies up to 2MHz. The one specification we were unable to locate on these particular parts are their rated temperature. So we still don't know what a safe operating temperature might be for them. This brings us to the subject of cooling the PWM.
As of right now, there are no alternative cooling solutions so we had to come up with some options our selves. The only thing we could ascertain is using the tried and tested Swiftech MC-14 solution. We have been using MC-14s on PWM MOSFETs for a long time and always had great success. Unfortunately, this didn't work out so well because the MC-14s didn't fit. Shame on EVGA for not allowing us to use our favorite Swiftech heat sink. Instead, we had to resort to Enzotech MOS-C1s. These are quite a bit smaller and we weren't sure if they would even be able to handle the heat from the PWM MOSFETs. Here are a couple photos of the setup with the Enzotech MOS-C1s and the problem with the MC-14s.
We can now look at the results of the load testing of each setup. We also threw in the results of simply changing out the thermal pad on the existing cooler with that of Sekisui #5760 thermal tape. The load testing was done with one hour of OCCT Mix using Everest Ultimate to chart the PWM temperatures throughout testing. Ambient temperature of the room was a controlled 23C~24C as measured directly above the setup with an Extech TM200 digital thermometer. Here is how the three different PWM cooling solutions shook out:
We honestly can't say this is what we were expecting. It isn't often that a stock PWM cooling solution is going to perform as well as one that is slightly tweaked by an end user, but that is definitely the case here. We have to admit that the competition, Enzotech MOS-C1s, weren't really the toughest of competition seeing as they only covered a portion of the large MOSFET ICs. We really would have liked to get Swiftech MC-14s or Enzotech BMR-C1 heat sinks on there but the space just wouldn't provide that luxury. We also thought that changing out the thermal pad for high quality thermal tape may have done some good but that clearly hindered performance. This is likely due to the base of the heat sink not being completely flat and contact not being perfect on the ICs.
With the thermal pad used, the contact on all ICs is even and complete as is the contact on the base of the heat sink. We still think there are better cooling solutions for this PWM but as of right now, stock is where it is at for the EVGA X58 SLI.
January 25, 2010
With the dawn of the USB 3.0 and SATA 6Gb/s age, motherboard manufacturers have been quick to adopt both of these new technologies. Gigabyte in particular has been at the forefront of technology and ...
December 28, 2009
What is black and red and full of sexy all over? Well we can't tell you because it is Classified. That's right, this is another installment of the EVGA Classified show. Our guest star is of the P55 va...
December 20, 2009
Gigabyte has a long-standing tradition of manufacturing some of the most reliable motherboards on the market but reliability is just one of many necessities when competing in the P55 market. Their n...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/13276-evga-x58-sli-lga-1366-motherboard-review.html
Posted By Date
[discussie] Intel P55/socket 1156 moederborden - Processors, Moederborden & Geheugen - GoT February 4, 2010 01:01 AM
2x5850 hytysuhde February 1, 2010 03:42 AM
Untitled document January 26, 2010 06:31 AM
New Mobo suggestions - EXTREME Overclocking Forums January 24, 2010 12:03 AM
yplayz XFX & EVGA Part1 yhard.z January 22, 2010 01:05 AM
LGA 1156 and Dual Video Cards - Facepunch January 2, 2010 02:01 PM
buying a new Mobo - Overclock.net - Overclocking.net December 27, 2009 01:44 AM
Want to push my OC, multimeter Q's - Overclock.net - Overclocking.net December 5, 2009 04:40 AM
EVGA X58 multimeter problem - Overclock.net - Overclocking.net December 4, 2009 06:29 PM
2 GPUs cause Win7 freeze - Tech Support Guy Forums November 26, 2009 08:24 PM
EVGA X58 SLI LGA 1366 Motherboard Review November 18, 2009 07:25 PM
4870X2 PCI-E x8 Bottleneck? - Overclockers Australia Forums November 17, 2009 08:00 PM
Crossfire HD5850 X58 vs P55 ( 16x 16x VS 8x 8x ) + CPU bottleneck test. (updated) November 10, 2009 10:41 PM
Crossfire HD5850 X58 vs P55 ( 16x 16x VS 8x 8x ) + CPU bottleneck test. November 10, 2009 07:06 PM
PCI-E question November 6, 2009 02:04 AM
Technology Geeks - The New Stuff: EVGA X58 SLI LGA 1366 Motherboard Review October 23, 2009 08:04 AM
EVGA X58 SLI LGA 1366 motherboard October 1, 2009 06:52 AM
EVGA X58 SLI LGA 1366 Motherboard Review September 18, 2009 12:34 PM
GTX 285 SLi on 16x PCI and 8x PC - Overclockers Australia Forums September 15, 2009 08:19 AM
SLI 8x 16x and CPU's/Mobo's - NVIDIA Forums September 15, 2009 07:51 AM
[discussie] Intel P55 moederborden - Processors, Moederborden & Geheugen - GoT September 11, 2009 04:29 AM
CF/SLI 8x vs 16x for p55 chipsets - Overclockers Australia Forums September 8, 2009 06:59 PM
CF/SLI 8x vs 16x /p55 and scaling - Graphics cards - Monitors/Video September 8, 2009 02:39 AM
CF/SLI 8x vs 16x /p55 and scaling - Graphics cards - Monitors/Video - Whirlpool Broadband Forums September 8, 2009 01:01 AM
[OFFICIEL] X58 SLI September 7, 2009 09:39 AM
PCQandA.com - Viewing topic #508879 - EVGA X58 Motherboard August 29, 2009 12:51 PM
which component burns the easiest? - Page 2 - PC Perspective Forums August 13, 2009 02:54 AM
Untitled document August 6, 2009 09:53 AM
??????? ????? - Overclockers.ge - The Way It's Meant To Be Overclocked August 3, 2009 10:42 AM
ASUS P6T Deluxe @ [H] - Page 15 - [H]ard|Forum July 26, 2009 08:03 AM
EVGA x58 matx..any reviews out there? - techPowerUp! Forums July 24, 2009 12:01 PM
mushkin enhanced Forums • View topic - Mushking 998961 BIOS set up? July 23, 2009 03:26 PM
VTT is much higher than what is set in BIOS July 22, 2009 10:36 AM
EVGA X58 SLI LGA 1366 Motherboard Review - Intel , Motherboards and Memory July 16, 2009 08:02 AM
Mother I7, dudas... - 3DG July 14, 2009 10:41 PM
True Enthusiast advice needed, actual experience preffered <3 - OverclockersClub Forums July 11, 2009 01:28 PM
Maximus 2 mobo, Which video card/s to run at full 16X July 11, 2009 09:28 AM
Maximus 2 mobo, Which video card/s to run at full 16X July 10, 2009 06:41 PM
vDIMM and VTT differential July 6, 2009 10:12 PM
NCIX.com - Buy EVGA X58 ATX LGA1366 DDR3 3PCIE-16 PCI-E1 2PCI SLI SATA2 eSATA Dual GBLAN Motherboard - 132-BL-E758-A1 In Canada. July 4, 2009 04:43 AM
News des 8. Januar 2009 | 3DCenter.org June 29, 2009 02:50 PM
[GO] i7 Deals - Corsair DDR3 and EVGA X58 - TechEnclave June 29, 2009 05:30 AM
Gaming Only Card and I'm Undecided June 27, 2009 06:48 PM
Review of EVGA X58 3X SLI 132-BL-E758-A1, Review EVGA X58 3X SLI 132-BL-E758-A1 - Mainboards - Page 1 of 2 June 20, 2009 08:34 PM
Motherboard choices. - Overclock.net - Overclocking.net June 20, 2009 12:43 PM
does vdroop impact vtt? June 11, 2009 12:36 PM
Need help getting to 1866 - PureOverclock Forums June 9, 2009 06:16 AM
ASUS P6T Deluxe @ [H] - Page 15 - [H]ard|Forum May 28, 2009 01:32 PM
DO : EVGA X58 SLi @ 18900 - Dealer's Paradise - TechEnclave May 28, 2009 05:16 AM
EVGA | Products May 27, 2009 03:34 PM
Week of January 4, 2009 May 27, 2009 08:50 AM
Futuremark - News - Newsarticle May 24, 2009 02:14 PM
Review of EVGA X58 3X SLI 132-BL-E758-A1, Review EVGA X58 3X SLI 132-BL-E758-A1 - Mainboards - Page 2 of 2 May 22, 2009 07:12 AM
Evga X58 Sli ultimate overclocking/ overview/ discussion thread - Page 5 - XtremeSystems Forums May 21, 2009 02:08 AM
Evga X58 Sli ultimate overclocking/ overview/ discussion thread - Page 4 - XtremeSystems Forums May 20, 2009 11:56 AM
Schede madri X58 e overclocking Intel i7 - Windows Live May 19, 2009 04:11 AM
Fed up waiting for Classified - What to get then? - XtremeSystems Forums May 10, 2009 01:45 PM
Do : Evga X58 Sli - Dealer's Paradise - TechEnclave May 9, 2009 08:59 AM
EVGA X58 SLI Motherboard Review - Futuremark / YouGamers Forums May 3, 2009 07:15 PM
The Official Core i7 (Intel's nehalem) Thread - Page 2 - Digit's Technology Discussion Forum May 3, 2009 03:45 PM
Rampage II Extreme vs P6T6 WS Revolution - Page 2 - EXTREME Overclocking Forums May 3, 2009 05:28 AM
Technology Geeks - The New Stuff May 1, 2009 04:08 PM
[H] Enthusiast --- www.hardocp.com April 29, 2009 07:33 PM
??&#12288;??PC???????: EVGA X58 SLI LGA 1366 Motherboard ???? April 25, 2009 12:04 AM
techPowerUp! :: Review Database April 24, 2009 02:58 PM
EVGA x58 sli Review - techPowerUp! Forums April 23, 2009 11:33 AM
Which GTX285? - Guru3D.com Forums April 21, 2009 04:31 AM
The X58 Motherboard Reviews - Forums on the BleedinEdge April 16, 2009 02:40 PM
EVGA X58 SLI LGA 1366 Motherboard Review - Hardware Canucks April 14, 2009 05:29 PM
EVGA X58 SLI LGA 1366 motherboard - PCSTATS.com April 10, 2009 04:20 PM
OverclockersClub Forums > Need advice for i7 cooler April 10, 2009 02:13 PM
Need advice for i7 cooler - OverclockersClub Forums April 8, 2009 09:05 AM
my I7 - OverclockersClub Forums April 5, 2009 08:01 PM
Gaming Only Card and I'm Undecided April 5, 2009 07:41 PM
EVGA X58 SLI LGA 1366 Motherboard Review April 5, 2009 08:09 AM
F3-12800CL9T-6GBNQ EVGA x58 - GSKILL TECH FORUM April 5, 2009 03:14 AM
EVGA X58 SLI Review @ HWC - OCXtreme.org Forums April 4, 2009 08:27 AM
EVGA X58 SLI LGA 1366 Motherboard Review @ Hardware Canucks April 3, 2009 04:29 PM
Revamped Build For A CoWorker - OverclockersClub Forums April 3, 2009 12:52 AM
EVGA X58 SLI LGA 1366 Motherboard Review April 2, 2009 07:02 PM
RE: CPU coolers that fit the X58 April 2, 2009 04:37 PM
Komplett.no - EVGA X58 3xSLI, Socket-1366 April 2, 2009 02:28 PM
