Review Contents:
Antec Skeleton Open Air Case Review
by lemonlime     |     December 28, 2008
Impressions cont.
A rats nest of header cables are bundled up behind the front IO panel. Unlike some of the rainbow colored cables we’ve seen, Antec has kept things looking clean with black insulation on all of the leads.
Aside from the massive top-mounted 250mm fan, Antec includes a special 92mm fan that clips to the front of the hard drive cage. Because the lower deck of the Skeleton is obstructed, none of the components below will receive airflow from the “Super Big Boy”. There are no markings visible on the underside of the fan to hint at its OEM manufacturer or its specifications unfortunately. Antec doesn't tell us a single thing about this fan aside from the fact that is a 92mm fan with a 4-pin molex connector. Considering the Skeleton’s enthusiast target audience, buyers would have appreciated a posted CFM and RPM rating at the very minimum.
Behold the “Super Big Boy” in all its glory; a 250mm fan with clear plastic fins and multiple LEDs. Again, Antec provides absolutely no information on the fan. We can’t tell you its rotational speed, or rated CFM output. We have no idea why Antec wouldn’t boast about this huge fan’s output, especially considering the PR friendly numbers associated with oversize fans.
Two optical drives and two 3.5” hard drives can be installed in the Skeleton’s lower deck and metal latches are included for a semi-tool less design. Screws are still used on the exterior walls of the case to secure the drives.
The mesh grille can be removed on either side of the Skeleton and makes fishing wires behind the optical and disk drives a bit easier. There are also some openings on the top of the grille to secure hard drives outside of the case, which we’ll get into a bit more later.
There are two thumb screws on either side of the frame to lock the lower deck in place. Releasing them allows the entire deck to slide out on rails.
With the deck pulled all the way out, it is easier to access the motherboard and other components. The motherboard tray sitting on the deck can also be removed, although we don’t see why it would be necessary to remove it. Antec really should have secured the expansion card bracket to the deck or motherboard tray and not the frame. Because of this, expansion cards have to be removed when pulling out the deck and has to be removed for taller heatsinks.
February 15, 2010
Cooler Master has a long history of building quality cases and in this review we take a look at their limited edition HAF 932 AMD Edition enclosure.  This case offers all of the best features from the...
January 31, 2010
The mid tower case market is cluttered with products all vying for your attention but Silverstone's new Fortress FT02 dares to be different by incorporating a new "stack cool" design for component pla...
January 26, 2010
Lian Li is a case manufacturer that has been long known for their outstanding attention to detail and high end quality of everything from high-end lower-tier chassis.   In this review we take a look a...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/12997-antec-skeleton-open-air-case-review.html
Posted By Date
Antec Skeleton case - Build and Review by HardwareCanucks.com February 24, 2010 10:59 AM
Geeks3D Daily News Round-up (2008.12.31) And Happy New Year! - 3D Tech News, Pixel Hacking, Data Visualization and 3D Programming - Geeks3D.com January 15, 2010 02:05 PM
[H] Enthusiast - December 1, 2009 08:20 PM
Antec Skeleton - Overclock.net - Overclocking.net November 21, 2009 12:09 AM
News Archives | [H]ard|OCP November 2, 2009 05:14 PM
News Archives | [H]ard|OCP August 4, 2009 06:39 PM
ASUS Arctic Square CPU Cooler $10 after $20 MIR - Page 2 - SlickDeals.net Forums July 3, 2009 08:12 PM
Best Cooler for AM3 less than $70 - Page 2 - Overclock.net - Overclocking.net June 16, 2009 07:16 PM
Antec Skeleton open air case review - Icrontic Forums June 9, 2009 09:00 PM
Antec Skeleton Open Air Case Review @ Hardware Canucks June 5, 2009 07:10 PM
News around the web: Windows 7 takes shape - TechSpot News May 25, 2009 01:38 PM
Review of Antec Skeleton, Review Antec Skeleton - Cases - Page 1 of 5 May 24, 2009 02:21 PM
techPowerUp! :: Review Database April 29, 2009 06:32 PM
Geeks3D Daily News Round-up (2008.12.31) And Happy New Year! | The Geeks Of 3D - 3D Tech News April 26, 2009 04:24 PM
PinoyDSL Network - Antec Skeleton Philippine DSL Network Forum April 24, 2009 10:45 PM
Antec Skeleton Open Air Case - PCSTATS.com April 21, 2009 03:26 PM
Tech Station V Normal Case April 20, 2009 08:21 AM
Antec Skeleton Open Air Case Review - Hardware Canucks April 14, 2009 04:24 PM
Banchetto Microcool 101 - Pagina 2 - PcTuner Forum April 14, 2009 11:54 AM
PcTuner Forum - Visualizza messaggio singolo - Banchetto Microcool 101 April 11, 2009 09:25 AM
The Antec Skeleton build - Page 2 - techPowerUp! Forums April 9, 2009 10:35 AM
Antec - Reviews April 7, 2009 12:42 AM
