Samsung LN52A850 52” 120Hz, 1080P LCD TV: The Living Review
by Michael "SKYMTL" Hoenig     |     November 27, 2008
Upscaling
If you are using the LN52A850 as your everyday TV, of its main uses will be to upscale all of the standard definition 480i signals to fit the larger real-estate a 52” screen provides. To avoid the distortion that comes with stretching a 4:3 image to a 16:9 screen, I decided to keep the aspect ratio unchanged for incoming standard definition signals.
Click on image to zoom (1280 X 720)
Like many other things about this Samsung TV, the upscaling engine can handle standard definition signals extremely well and is able to significantly improve their overall quality. Granted, there are still some artifacts apparent but nothing like I have seen with other sets in the past which have made SD signal viewing a chore at best.
Viewing Angles
Click on image to zoom (1280 X 369)
These new generation of LCD TVs are nothing like their predecessors which were known for their horrible viewing angles. As you can see from the composite image above, there is very little contrast or color shift as you move to even the more extreme viewing angles. There is a bit of black level loss but other than that, if you are unfortunate enough to be somehow watching the LN52A850 from the side of the screen at least you will still have something to look at.
Latest Reviews in Consumer Electronics
December 5, 2011
Samsung's 2011 HDTV lineup is one of the strongest around in a take-no-prisoners market and their UN55D8000 is currently one of their flagship products.  Retailing for just south of $3000, the D8000 h...
November 7, 2011
$2000 is more money than most people would pay for an HDTV but Samsung's new UN55D7000 is one of the few products that bridges the gap between lower quality sets and the ultra high end market.  On pap...
April 3, 2011
In an industry which was pummeled by the recession, there really hasn't been all that much released over the last two years in the ultra high end HDTV market.  However, Samsung has introduced one of t...
