Intel Core i7 "Nehalem" 920, 940 & 965 XE Processor Review
by MAC     |     November 3, 2008
Feature Test: The Return of Hyper-Threading
After the less-than-successful implementation of Hyper-Threading that we experienced with the Pentium 4, we were not particularly excited to this feature make a comeback. However, Intel assured everyone that the numerous architectural advancements they had made to Nehalem were specifically designed to eliminate any of the bottlenecks that Hyper-Threading can cause.
It doesn't matter how technologically jaded you are, opening the Windows Task Manager on a Core i7 system is a smile-inducing experience.
With it's shorter, faster, more efficient pipeline (ability to simultaneously process up to four instructions), can Nehalem truly make Hyper-Threading a worthwhile feature with real-world performance gains? Let's find out.
Intel Core i7-965
- HT Enabled
Intel Core i7-965
- HT Disabled
Performance Difference
3DMark Vantage: CPU Score1954614644+33%
Valve Particle Simulation Benchmark153133+15%
Cinebench R10 Multi-CPU1856916067+15%
x264 HD Benchmark27.23 fps21.55 fps+26%
WinRAR 3.71 Compression2:393:02+15%
We think a "WOW" is called for. Intel have come through with the predicted 20-30% performance gains and then some. Nehalem was always touted as being a multi-threading monster, and this certainly proves it. Clearly, if you run heavily multi-threaded applications, the Core i7 series is a very attractive proposition.
Latest Reviews in Processors
February 1, 2012
Being the newest and highest-end addition to AMD’s A-series APU lineup, not only does the A8-3870K feature the much raved about integrated Radeon HD 6550D, but it comes with fully unlocked multipliers...
November 14, 2011
Intel's X58 platform has been around for over three years now (yes, it really has been that long) and for many a changing of the guard in the enthusiast market couldn't come soon enough.  Replacing th...
October 11, 2011
After many, many years of gossip, presentations, leaks, and showcases AMD's new Bulldozer processors are finally here. This is AMD's attempt at making an architecture with significant multi-threaded p...
