Intel Core i7 "Nehalem" 920, 940 & 965 XE Processor Review
by MAC     |     November 3, 2008
Feature Test: Memory Scaling
Back in mid-2003, Intel introduced the 875P 'Canterwood' chipset, which featured the company's first consumer-oriented implementation of the dual-channel memory interface. This configuration has successfully lasted us until the present day. However, with Nehalem Intel have kicked things up a notch, unveiling a triple-channel memory configuration. Teamed up with the new integrated DDR3 memory controller, we have very high expectations for this new combo.
Intel Core i7-965
- Triple Channel
Intel Core i7-965
- Dual Channel
Intel Core i7-965
- Single Channel
3DMark Vantage: CPU Score195461951319484
Valve Particle Simulation Benchmark153153153
Cinebench R10 1-CPU425242404222
Cinebench R10 Multi-CPU185691836818284
x264 HD Benchmark27.23 fps27.21 fps27.06 fps
WinRAR 3.71 Compression2:392:443:05
SuperPI 1M12.960s13.061s13.207s
SuperPI 32M12:04.75512:08.35612:57.356
We re-ran these benchmarks over and over and over again, because we were quite simply puzzled. However, as you can see, generally speaking Nehalem is certainly not memory bandwidth limited. In fact, the only time we noticed a significant performance difference between single and triple-channel is during WinRAR compression, which is a completely memory bandwidth bound workload. There is also an appreciable difference in SuperPI, but even there the difference is nowhere near as large as what we would expect. This is a significant improvement over the Core microarchitecture, which would be hugely bottlenecked by a single-channel memory interface.
Let's see if the synthetic tests can shed any light on this phenomena:
In their native triple-channel memory configuration, the Core i7 processors produce some extremely impressive bandwidth numbers. In fact, the results demonstrate that at DDR3-1066 the Core i7 has nearly 100% more memory bandwidth than the previous Core 2 architecture running at dual-channel DDR2-1066. Even in dual-channel mode, the Core i7 series have almost 90% more bandwidth than previous processors. In single-channel mode, bandwidth drops precipitously, but it still equivalent to a dual-channel DDR2 interface. Clearly, Intel have done a tremendous designing Nehalem's memory architecture.
On the latency front, we also see some tremendous improvements. The integrated memory controller and triple-channel memory combine to produce the lowest latency numbers that we have ever seen. Interestingly, there is clearly a latency hit when utilizing the triple-channel mode since in dual-channel mode latency is 15% lower.
What can we say? From a real-life perspective, the triple-channel memory configuration does not really appear to be necessary for the consumer market. Having said that, our sample of benchmarking applications was fairly limited for this test, so it is too early to make a definitive judgement. However, when you consider the mighty Everest results, it is clear that the triple-channel DDR3 memory and integrated memory controller are a tremendously potent combination, and we look forward to seeing some insane new DDR3 bandwidth world records in the coming weeks.
Latest Reviews in Processors
February 1, 2012
Being the newest and highest-end addition to AMD’s A-series APU lineup, not only does the A8-3870K feature the much raved about integrated Radeon HD 6550D, but it comes with fully unlocked multipliers...
November 14, 2011
Intel's X58 platform has been around for over three years now (yes, it really has been that long) and for many a changing of the guard in the enthusiast market couldn't come soon enough.  Replacing th...
October 11, 2011
After many, many years of gossip, presentations, leaks, and showcases AMD's new Bulldozer processors are finally here. This is AMD's attempt at making an architecture with significant multi-threaded p...
