| by AkG | November 6, 2008 | ||
| Interior Impressions pg.3 Interior Impressions Con'tAs we have said in the past the motherboard area of any case is what will make or break the design. In this instance, Cooler Master’s engineer’s went for the Winnebago method and give you a down right unbelievable amount of room. This room is further increased by the dual PSU design, in that right above the motherboard is enough free space to mount a PSU…even though you have it mounted on the bottom. This right here will remove a lot of the hassle factor with installing a motherboard. Let’s face it; the more room you have to maneuver the motherboard into position, the less likely you are to bash it or your fingers off on some ill placed corner; and anything which saves you blood, sweat and tears has to be a good thing. Before we move on we would like to mention the motherboard tray is not removable and is rather an integral part of the case. There are pros and cons to removable motherboard trays and while we usually prefer to have it removable, the HAF is the exception since there is more than enough room within to move around. The other thing worth mentioning is the motherboard standoff holes are not labeled, but they have included a fold out map with all the holes cut out. This means you have to simply lay this map in position and screw in all the standoffs you need for your style of motherboard. While this is more effort than having the various holes labeled it is still a heck of a lot better than leaving you to fend for yourself. Flipping the case over (and removing the other side panel) we can see that Cooler Master has taken the time to really think about and then engineer a great cable management system. Many cases on the market allow you to route your cables behind the motherboard on the other side of the case but this is the first time this idea has been taken to the Nth degree. Unlike others which give you a cutout at the bottom to route the various power connectors with one along the side (or leave this area open making it one big hole) to bring the cables back and a final at the top for your 12v 4/8 pin power cable; this gives you all these and a heck of a lot more. At the bottom of the case you have an extra large opening which will make pushing all your cables to the other side much easier than usual. We personally hate it when this is just a little tiny (almost afterthought) cutout; and you have to thread one cable at a time through it or you are going to end up with a jam. The HAF on the other hand has a cavernous hole which easily twice the normal size. This really does make a difference and should speed up cable routing immensely. Along the side of the motherboard tray we have not one but two large cutouts for bringing cables back to the proper side of the case. In a nut shell one can be used for your motherboard’s power connector while the other can be for your SATA and IDE connectors. Ensuring that the protective covering of your various cables will not be worn away over time these two holes are rounded (and just like all the other holes) have no sharp edges. We would have liked to have seen plastic protective sheaths around all the holes but we can understand why they are not included on a model in this price range. The top of the motherboard area has not one, not two, but three cutouts for cable routing. Towards the back of the case you have two smaller holes which are obviously intended for your 4 or 8 pin 12v CPU power cable. As motherboard manufacturers have not decided on what is the best place to put this plug, this dual design is perfect as it allows you to get a heck of a lot closer to it before having to bring the cord back to the motherboard area. It may be nit picking but nothing ruins the look of a good clean case than a power cord draped half away across the top of the motherboard. The third hole is relatively long and this allows you to easily route other cables behind the motherboard tray. For example you can hide the top fan(s) molex plugs using this area or heck, depending on your motherboard even use this long one to bring over your 4/8 pin adapter. With all these holes you have options, and you really can never have to many options now can you? Before we continue we would like to mention the abundance of zip tie hold-downs Cooler Master has made available. They give you so many of these tie-down points it looks like a giant backwards C (just inside the cable routing holes). With all these holes and tie-downs you can be as neat and tidy as you want to be; and you don’t have to compromise or modify the integrity of the case to do it. It really is nice to see Cooler Master go that extra mile; and it should pay dividends in loyal customers pretty darn quick. We have left the biggest and most innovative feature of this case for last. With all these tweaks and cunningly crafted designed enhancements, Cooler Master has pulled off another major coupe with the inclusion of a cutout for your aftermarket CPU heatsink backplate. No longer will you have to remove the motherboard just to install your newest and shiniest cooler! This to us is such a breakthrough and such a paradigm shift it makes all other cases on the market look down right antiquated. Now maybe we are a little biased as we do change our coolers like some people change their wardrobe, but if we had a nickel for every new enthusiast who was afraid to buy a certain cooler because it meant yanking their motherboard, we would have bought and retired to the Cayman Islands long ago (actually we would have enough to not only buy the Grand Cayman Islands but change its name to the Grand Canuck Islands). For all you first time builders out there this little feature will make your life so much simpler; and should put this case at the top of your “serious consideration” list. Some people might say this is nothing more than an obvious improvement or even a “why didn’t we think of that” kind of deal; but to us the ability to see the “obvious” before everyone else can is the true mark of genius. It may seem simple and obvious in retrospect but if really was that simple or that obvious why did no one else do it before now? Bravo Cooler Master, you have certainly cemented the HAF 932 as a ground breaking case. Taken as whole this interior simply blows away all misgivings any enthusiast may have about the external looks of this case. The HAF may have a unique styling but all this style and personality hides what is quite simply the best internal layout we have seen in a long while. From the small design tweaks which will make installation easier; to the cable management options, to that amazing backplate cutout, there simply is no reason to ignore this case. | ||
| Latest Reviews in Computer Cases | |||||||||
