| by FiXT | October 30, 2008 | ||
| Test Setup / Overclocking Methodology Test Setup ![]() Test Platform:
Testing will occur on a Highspeed PC Standard Top Deck Tech Station, and not in a traditional case. This allows easier access to the motherboard for the constant poking and prodding that is required during the reviewing process. The setup remained as pictured during the duration of the benchmarking and stability overclocking process. However, we utilized a 2x1GB Crucial Ballistix PC2-6400 .16FD5 memory kit during the maximum overclocking tests. Overclocking MethodologyAlthough it is not part of Gigabyte’s enthusiast-oriented EP45 Extreme series, we still expect to see some solid overclocking from this new mainstream P45 model and we are definitely going to find out what it is truly capable of. The overclocking section is definitely the part of our reviews that we take the most pride in, and we spend an excruciating numbers of hours testing, tweaking, failing, and succeeding in order to give you the best possible insight into each motherboard’s overclocking capabilities. After all, if you are anything like us, the overclocking section is the first (and often last!) part that you read when checking out a motherboard review. For the purposes of this review, our overclocking efforts will primarily focus on five main areas: highest stable FSB overclocking, highest stable memory overclocking, highest stable overall overclocking, maximum benchable FSB overclocking, and maximum benchable memory overclocking. In the first three overclocking tests, we put an emphasis on stability. While the question “What is stable?” could be debated endlessly, we have devised a methodology that combines a wide range of programs that test the stability of the entire system. Here is the suite of applications that will be run in order to validate each of the overclocks:
Altogether, the above suite should provide enough stress testing to ensure a completely stable overclock, however we are always up for new suggestions. As always, no two systems are ever alike, so your results may vary. Also, overclock at your own risk! If you aren’t fully confident in what you are doing, feel free to stop by our forums and our helpful members will be glad to offer some assistance. | ||
