Categories
Review Contents:
CPU Water Block Round Up APOGEE GT/GTX vs. STORM vs. FuZion vs. APOGEE vanilla
by Misoprostol     |     April 25, 2007
Installation:
Installation using the stock Swiftech mounting hardware is dead easy. Swiftech provides a full colour instruction manual that looks, feels, and smells like high quality. Honestly I’ve installed my old APOGEE dozens of times, so I didn’t actually use it, but I read it over and the instructions are amazingly simple and clear. Swiftech is really raising the bar in terms of making water cooling more accessible for non-technophiles.
Things start to get a little bit more complicated once you get past the basics of how to mount the block to the board. For advanced users, Swiftech recommends using a second O-ring that is included in the package in order to bow the base and achieve slightly lower temperatures, and boy does it ever work.
(Original O-ring right, Thick O-ring left)
There is a clear difference in size between these two O-rings with the one on the left being substantially thicker. It was moderately difficult to install this O-ring into the disassembled block (Swiftech kindly provides an allen key which is necessary for taking the block apart, although mine came stripped for some reason… Fortunately the one that came with the APOGEE GTX sample was fine, so I’m assuming it was a fluke). I found the easiest way to install the O-ring was to work my way around the perimeter slowly forcing it as deeply into the groove, while the block and O-ring are clean and DRY. This give the rubber a little bit of grip in the groove, and gives you some time to slap the base plate on and get those allen screws in.
You can see in the above picture that the base of the block is clearly bowed.
Latest Reviews in Water Cooling
September 8, 2008
In the past we have reviewed several products from CoolIT Systems. Both the Pure and the Elite passed through our lab and both received accolades while never offeri...
June 4, 2008
Even though CoolIT can be considered one of the new kids on the block when it comes to CPU cooling solutions, there isn't a doubt that they have made a name for them...
May 5, 2008
CoolIT hasn't been around for long but in a short amount of time they have proven themselves to be the company to go to for TEC cooling solutions. Today, we test th...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/1033-cpu-water-block-round-up-apogee-gt-gtx-vs-storm-vs-fuzion-vs-apogee-vanilla.html
Posted By Date
Watercooling blok - 9lives November 23, 2008
Need some opinions on my water cooled CPU setup - CPUs and Cooling - Forums - www.atomicmpc.com.au September 19, 2008
Thermaltake Bigwater 735 - Page 4 - Forums - OverclockingWiki.org August 14, 2008
EK-Supreme CPU - Acetal block good? - Overclock.net - Overclocking.net August 3, 2008
Watercooling with a CM 690 - Forums - OverclockingWiki.org August 2, 2008
Teraflopy.blogspot.com: Swiftech Apogee GT / GTX - test bloków wodnych + porównanie do Storm-a i Fuzion-a July 24, 2008
Best CPU Waterblock? - techPowerUp! Forums July 22, 2008
tips til vannblokk til GPU og CPU - Forum - Hardware.no July 16, 2008
