Categories
Review Contents:
CPU Water Block Round Up APOGEE GT/GTX vs. STORM vs. FuZion vs. APOGEE vanilla
by Misoprostol     |     April 25, 2007
The Technology
At the heart of the APOGEE GT is the same patented pin matrix design as the original APOGEE (the successor to the Storm) and part of what makes this design so great is that besides offering very large surface area for the water to contact, the lack of impingement means that water will flow much more easily and quickly around the loop, allowing for the use of less expensive, or equally expensive, but less noisy pumps.
(original APOGEE right, APOGEE GT left)
As you can see in the above picture, my APOGEE vanilla is a little worse for the wear, and the base is installed 90 degrees off of where it should be (it was corrected for the testing in this article), but more importantly if you look at the pins, the APOGEE GT uses MUCH smaller pins than the original APOGEE, giving it dramatically increased surface area, while still providing very large channels for the water to flow between the inlet and the outlet.
The APOGEE GTX uses the same diamond pin matrix base plate as the APOGEE GT, but the inlet and outlet are further apart in order to give the water more time to pass over the pins inside. Also, due to the diagonal orientation of the barbs vs. the horizontal orientation of the barbs on the GT, the APOGEE GTX has slightly more internal turbulence which is good for heat exchange.
Although I didn’t measure flow rates, it honestly didn’t make a noticeable difference when I was watching the bubbles zoom around the loop as they bled out, unlike the STORM, which seemed to slow the water to a standstill….
I promised to mention the O-ring later in this article, so here it is: Another innovation that the APOGEE GT brings to the table is that it ships with both a small O-ring (an “O” shaped piece of rubber that serves to seal the perimeter of the block where the copper contacts the acetal top housing) and a fatter one.
The reasoning behind this accidental discovery that Swiftech’s engineers made is that if a thicker O-ring is installed, it would cause the base of the block to warp or become slightly convex, which means that when pressure is applied from the top down on the four corners, and then pressure is applied to the center of the base from the CPU upward, that the block’s contact surface would end up overall flatter than if it were to start flat.
Latest Reviews in Water Cooling
September 8, 2008
In the past we have reviewed several products from CoolIT Systems. Both the Pure and the Elite passed through our lab and both received accolades while never offeri...
June 4, 2008
Even though CoolIT can be considered one of the new kids on the block when it comes to CPU cooling solutions, there isn't a doubt that they have made a name for them...
May 5, 2008
CoolIT hasn't been around for long but in a short amount of time they have proven themselves to be the company to go to for TEC cooling solutions. Today, we test th...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/1033-cpu-water-block-round-up-apogee-gt-gtx-vs-storm-vs-fuzion-vs-apogee-vanilla.html
Posted By Date
Watercooling blok - 9lives November 23, 2008
Need some opinions on my water cooled CPU setup - CPUs and Cooling - Forums - www.atomicmpc.com.au September 19, 2008
Thermaltake Bigwater 735 - Page 4 - Forums - OverclockingWiki.org August 14, 2008
EK-Supreme CPU - Acetal block good? - Overclock.net - Overclocking.net August 3, 2008
Watercooling with a CM 690 - Forums - OverclockingWiki.org August 2, 2008
Teraflopy.blogspot.com: Swiftech Apogee GT / GTX - test bloków wodnych + porównanie do Storm-a i Fuzion-a July 24, 2008
Best CPU Waterblock? - techPowerUp! Forums July 22, 2008
tips til vannblokk til GPU og CPU - Forum - Hardware.no July 16, 2008
