Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 22, 2007, 07:06 PM
3.0charlie's Avatar
Thumbs up
Hello all, first post here. I would like to say that this P180 w/c rig is a great build, and has given me a few ideas for my next one.
I've already built 2 similar rigs with the P180. Since I've used the 'net extensively for ideas, let me add a few pics to give others ideas too!
Components: Antec P180, eVga 680i, Intel E6400, OCZ 700w, OCZ Gold 6400, WD Raptor 36Gb, Seagate 360Gb x2, eVga 8800GTS 640Mb, Swiftech Ultra+ WC.
Customers have selected that the CPU be oc'ed to 3.0 and 3.2 respectively. I actually reached 3.6 on the first one - idle temp was 24C, load temp was 37 load with Orthos.
Thanks for the ideas,
John
Old May 22, 2007, 09:28 PM
Babrbarossa's Avatar
Super Moderator
As I said on the other thread- welcome, and thanks for the nice build pics. You're no doubt aware of this already, but if you get the cable management blues with the p180, the newer p182 makes things alot easier with cutouts behind the motherboard tray for cable routing- much easier! And the same price as the p180. (about 140 at Direct Canada)
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old May 22, 2007, 09:36 PM
3.0charlie's Avatar
Yup, cable management is pain in the derriere when using the P180. But I can't use the 182, since Antec decided to locate the fan switches exactly where I cut holes for the rad hoses... and they also added 2 holes exactly where I attach the Micro-res.
I did add cut-outs in the 2nd rig case - all over the place behind the motherboard tray (used some caterpillar strips to protect the wire harnesses from the sharp edges) to ease cable management.
John
Old July 25, 2007, 11:57 PM
Very cool build log and post Babrbarossa! Your work inspired me to convert my P180 to water as well!
I made some minor tweaks as to how I laid out things - very happy with the results. Running a E6700 @ 3.7Ghz with max load temps in the upper 50C range and it idles @ 39C now.
I'll follow up with a few pics in a sec as this is my first post here.
Old July 26, 2007, 12:01 AM
Some pics of my P180 rig converted to water.
Old July 26, 2007, 12:33 AM
sswilson's Avatar
Super Moderator
Looks great!
Did you make the mount for the resevoir yourself or did you find that kind of stock somewhere?
I've considered picking up a medium sized mechanno set in order to get a bunch of pre-manufactured pieces just like the ones you have. :)
Welcome to HC!!!!!!
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old July 26, 2007, 12:36 AM
Level up: 7% Level up: 7% Level up: 7%
Level: 23 - 1,384 points to level up
While I give much credit to the two who have done this, I'm not really digging the cramped quarters in the p182, but looks awesome either way.
Old July 26, 2007, 06:50 PM
Originally Posted by sswilson View Post
Looks great!
Welcome to HC!!!!!!
Thanks! The reservoir is a Swiftech MCRES-Micro and came with the mounting hardware. Very nice little unit and fairly inexpensive to boot! (Jab-Tech and Petra's tech shop sells them for under $20 US.)
True, the P180 series case is a bit cramped when it comes to water cooling. There are other cases out there better suited to water cooling - but it's what I already owned and as far as air cooled cases go it's probably near the very top of the heap.
  #19 (permalink)
Old August 7, 2007, 03:24 PM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Default nice post
Review and water cool guide was really helpful. I wonder if there are any liquid "elements" that can be used to cool electronic parts by complete immersion without conducting or damaging components? Like the watercooling pics too!
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
  #20 (permalink)
Old August 7, 2007, 07:39 PM
sswilson's Avatar
Super Moderator
Do some googling for oil immersion computer cooling or something like that. Virtually everything (including the PSU!!!!) can be immersed in mineral oil.
Doesn't cool very well though..... (works fine for the first while, but then the oil heats up and just retains the heat rather than wicking it away).
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 02:00 PM
Newbie Water Cooling Build -- Opinions? tehgooch Water Cooling 14 January 6, 2008 05:45 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 10:22 PM
P180 + 680i rig number 2 - WC 3.0charlie Water Cooling 10 June 13, 2007 02:37 PM
Water cooling build SHaCK Water Cooling 34 April 24, 2007 08:45 AM
