Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 24, 2008, 10:47 PM
Level up: 65% Level up: 65% Level up: 65%
Level: 9 - 84 points to level up
Default How to make you own Memory Cooler (RAM)
I found this article while surfing and thought I would share it with you guys, the original creator deserves a lot of credit imho:
HOW TO MAKE YOUR OWN MEMORY COOLER(56K UN-FRIENDLY) - Overclockers Australia Forums
It may look a little "ghetto" for some but the build looks promising, cheap and you can determine noise and cfm by the quality of fans used in the build.
Q6600@3.15Ghz|CNPS9500|P5WDH|4GbCrucial4-4-4-12|Sapphire 4850|OZC GameXtreme 700|XP64
Old July 24, 2008, 11:07 PM
Level up: 1% Level up: 1% Level up: 1%
Level: 12 - 400 points to level up
Looks allright to me. I thought of actually a similiar thing meselves :)
Old July 25, 2008, 12:39 AM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
That's kinda cool but if I was that guy, I would have went with blue since the rest of the lighting in the case was blue but that's just my $0.02.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
Old July 25, 2008, 12:43 AM
.001 after tax and inflation there bud
Old July 25, 2008, 02:01 AM
MacJunky's Avatar
Level up: 53% Level up: 53% Level up: 53%
Level: 12 - 192 points to level up
Someone should tell him that it is not 56k unfriendly, it is just 56k neutral.
See?
Phenom x4 9950 BE, Gigabyte MA790GP-DS4H, 2x2GB G.SKILL F2-8000CL5D-4GBPQ
250GB 7200.10/640GB&500GB 7200.11 'Cuda, Samsung SH-S203N/Pioneer DVR-112D
Radeon HD 3850 256MB, 22" Acer X223W
Corsair TX750W, Generic(?) ATX fulltower case (6x 5.25"/9x 3.5")
Sansui G-4700 receiver +2x 60w spks/Yamaha YST-M7
Old July 25, 2008, 02:26 AM
calvary1980's Avatar
people still use dialup? isp's in ethiopia are probably better than mine :p
- Christine
Cooler Master RC-690 | Thermaltake Toughpower 1000W | 6x Scythe S-Flex SFF21F Fans, EK-MultiOption 2 Port, dB-1 Compact, Swiftech MCR80, Swiftech Apogee GT | Abit IP35-Pro | Intel Q6600 @ 3.8Ghz | 2x1GB OCZ Flex XLC PC-9200 | Inno3D Geforce 8800 GTS 320MB
Old July 25, 2008, 09:32 AM
MacJunky's Avatar
Well, all ISPs in Canada fully suck - but that aside, in the more remote areas dialup must often be resorted to because a sat connection completely sucks and is a terrible experience.
We are getting off topic though.
Old July 25, 2008, 10:52 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Interesting. I just use the coat hanger method myself :)
Hockey Mod at your service
Old July 25, 2008, 10:54 AM
misterlarry's Avatar
Level up: 67% Level up: 67% Level up: 67%
Level: 14 - 197 points to level up
Cheap, likely efficient, and better looking than some.
GA-P35-DS3L Rev. 2.0 - Intel E8400 Wolfdale @ 3.0 GHz - Thermalright Ultra 120 Extreme - 4x2 GB Mushkin XP PC2-8000 - Gigabyte 8800GTSx512 MB
Arctic Cooling Accelero S1. Rev2. - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - XP Pro 64 SP2
Old July 25, 2008, 10:56 AM
CMetaphor's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 15 - 261 points to level up
Does that mean that the standard ATX mounts are spaced 80mmx160mm around the ram slots? really? If so, thats pretty darn cool! Time to check the wiki....
Current System: "Gale Force" (09-28-2008)
AMD X2 6000+ w/ TRUE (2x Scythe 120mm) | Asus Crosshair MB | 4Gb OCZ Plat.Rev.2 PC-6400 RAM w/ Corsair Memory Cooler | VisionTek 4870X2 2gig| Coolermaster CM Stacker 832 w/ 7x 120mm Fans (2x Tricool, 5x CM), 1x 80mm CM, and 1x Antec "Big Boy" 200mm Tricool Fan | Silverstone Strider 1Kw PSU | Seagate Barracuda 7200.11 500gig x 4 (Raid 1 & Raid 0)| 3x BenQ FP222w 22' Wide 5ms LCD Monitor & Matrox Triplhead2Go DE
Next system? Who knows...
