Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old July 25, 2008, 02:03 PM
Level up: 19% Level up: 19% Level up: 19%
Level: 15 - 524 points to level up
Originally Posted by BrainEater View Post
Nice !!!
I'm curious how well yer 'Nitro' connection works.....I've been eyeing it myself since it came out... I don't utilize all of my 10 mbit as it is tho.....
I DL from Giganews using their accelerator software and 10 concurrent connections, it stays pinned at 23mbit, 2.8 mbytes/sec
  #22 (permalink)
Old July 25, 2008, 02:31 PM
MacJunky's Avatar
Level up: 53% Level up: 53% Level up: 53%
Level: 12 - 192 points to level up
Brain&Sqee, speed is one thing, reliability, customer service, monthly bw caps, over usage charge rates, etc are another. Just look at how much you pay for those connections and how what you are paying for stacks up against other areas of the world. Canada is in the toilet when it comes to telecommunication and such in general.
Phenom x4 9950 BE, Gigabyte MA790GP-DS4H, 2x2GB G.SKILL F2-8000CL5D-4GBPQ
250GB 7200.10/640GB&500GB 7200.11 'Cuda, Samsung SH-S203N/Pioneer DVR-112D
Radeon HD 3850 256MB, 22" Acer X223W
Corsair TX750W, Generic(?) ATX fulltower case (6x 5.25"/9x 3.5")
Sansui G-4700 receiver +2x 60w spks/Yamaha YST-M7
  #23 (permalink)
Old July 25, 2008, 02:36 PM
Mibs's Avatar
Level up: 45% Level up: 45% Level up: 45%
Level: 12 - 226 points to level up
Originally Posted by Cptn Vortex View Post
Heh. Did you know the S775 mounting holes are exacly the right size to mount a 80mm fan? I found that out, mounted one on the screws for my Fusion WB, to cool my PWM
I didn't know this! Kinda neat when you think about it. I might have to do the same.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 2 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
  #24 (permalink)
Old July 28, 2008, 06:18 AM
Level up: 65% Level up: 65% Level up: 65%
Level: 9 - 84 points to level up
I'm going to build one of these this week and will post a couple of pics.
Always liked Eldonko's builds' but that just couldn't happen in my room....
Personally the radiator in the esky of ice and water was my favourite, have you tried adding salt, it will lower the freezing point (and thus melting point) of ice and give you another 4-5C I would guess. The copper radiator and the hose clamps should all be corrosive free, just need a good rinse afterwards.
Q6600@3.15Ghz|CNPS9500|P5WDH|4GbCrucial4-4-4-12|Sapphire 4850|OZC GameXtreme 700|XP64
  #25 (permalink)
Old August 1, 2008, 12:32 AM
Originally Posted by CMetaphor View Post
Just checked the offical ATX 2.1 standard .pdf document for the measurements. Did a little conversions annndddd:
Mounting holes are 72.39mm x 157.48mm.... Seems likes those bolts he used must be bent or slanted.
Well that was an excellent observation but that is why he commented to give the bolts 1mm of play. I built one and could only get 2 of the bolts in but it is mounted very firmly and the other bolts are acting like posts. Overall my cooling project lowered my load temps by 10C so far;
Air Cooling Project: 101. Lowered CPU load by 9-10C
Yes the cable management sucks but the rest is going fine.
