An anti-static floormat is a decent idea for where you sit. As for the surface, Ive always liked wood better than metal.
__________________ Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic My Heatware! | Got RMA? Tell us your experience! | VOIP Help? PM ME! |
concrete floor wood bench. all you need.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
Tile is probably not a good decision because a dropped tool or component could break the tile and it is generally more expensive. Vinyl is durable and easy to clean (especially if you basement is prone to flooding) but it could get cold and uncomfortable in a basement. A durable low pile carpet would be my first choice for a computer maintenance shop. I am assuming you do not mean Dremmel huge patterns or do a lot of soldering. These kinds of messier activities would dictate the more industrial suggestion of enaberif. As for table tops I would just get a cheap Ikea desktop to start. The Amon series are pretty durable and very cheap. As you figure out how many wires you need and what tools you need and all the little things that go into the particular jobs you work on you can fit the most useful layout of shelves, bins, table space, or what have you. If you need a bench you can hammer on then I would suggest making one out of laminated 2x4s (or better yet, salvaged wood like old palettes) as you can make it beefy enough to stand up and the thing will be nigh indestructible. These decisions are going to be hugely influenced by your tolerance to clutter (or the tolerance of your SO ).
__________________ Companion - E8400 - P5K SE - EN8600GT SILENT - 2x1G Ballistix (POS) - WD250 - X241W Server - Q6600 - P5E WS Pro - EAH3450 - 4X2G Redline - WD250 - Pioneer DVD-212 On the shelf - P5N32-E SLI - BFG 8800GTS 640M OC2 - Ballistix 2x1G 8500 4-4-4-12 - X-Fi Fatal1ty - 1xWD 150 Raptor |
| Quote:
It's almost like new after ~4 years. The other is an old office desk that my dad gave me(~5'x29"deep x28"H)..that's made out of steal with 3 steal drawers..and i bet it weighs 300lbs. The top is a very hard white plastic that doesn't mark or gouge easily...yet i never get any static charge from it. I find for me (~5'11") that 28"/29" is a good height.. maybe 30" could be better, but i sit when i work due to FUBAR back. The whole area is 101"Wx114"L...it gets tight. I have peg-board on one wall; from the top of desk to ceiling. I have 2x4' Flourescent's as well... and a desk-light that bends almost like a snake.. this works good w/9w CFL. I have 3-6'x30" bookshelfs, and an old over-the-toilet shelf unit for parts. Be creative... you don't have to buy a lot. I have an old "plate-rail" that my bro. made for me out of wood.. i cut it to size(6'6"), mounted it up high, and have mobos lined up on it.. ~12-15. GL.
Thanks for the info guys. Currently using an old wood desk, which is attached like an L-shaped to another unit that I got from old office furniture, all on a concrete floor for now but that is a bit cold. Gives me plenty of room for my own pc and a working area with a KVM switch for when I need to test a computer. I guess I was more worried about anti-static and what I should put on the carpet. Concrete is really making the wheel of my chair crackle alot and I'm afraid they will be busted before too long. Maybe I just need to organize thing a bit more.
If you have a concrete floor you could go with an EPOXY flooring. Properly applied and cured they are extremely tough. They leave a VERY nice finish... oils, fuel, nothing will stain it. It wont chip either.
@SiDiX007, Can you get epoxy floors cheap? I saw a reno show on the tele that had an epoxy floor and it looked really great but they said it was twice as expensive as marble or some crazy expensive figure. @Pike, Do not worry about static unless you go for a 70's vintage wool shag. The kinds of materials listed here will not build up significant static. If you are doing this for a hobby you can pretty much ignore static entirely; I do. If this is a business and you need to be extra careful drop the $60 on a good mat and wrist cuff and read a comprehensive HOWTO.
Plain padded rubber mats make good soft surface to stand on, and wewt they are non-conductive! Wooden work surface is fine and dandy, but pick up a Yoga Mat at a garage sale for a buck (or new for about $20), place it over the wood for a soft, non-slip, non-conductive, and non-case scratching surface! Use an old power supply, plugged in but turned off, as a ground. Simply attatch a wire to it, then the system case you are working on with an aligator clip, to complete the ground. I also have an anti-stat wrist band attached to it, ready for use. Believe it or not, I rare use either and have never had a problem even though my floor has carpet on concrete. Can't have enough power! Place a good surge protector on the side somewhere, and/or a UPS. If the walls are unfinished, consider adding more wall sockets, preferably on different circuits. I have two sockets in reach of my bench, on the same circuit. I then have three surge protectors, one very high qual and two mainstream. After all this, I only have six outlets free! They are taken up by lights, chargers, the PSU, monitors, speakers, and space for two computers. I also have at least two more computer power cables that are loose and ready to use for things like external drives etc, so it is very rare that I have to use one of the open sockets. I have yet to pop a fuse. Use long nails or screws in the wall to hang various cables from. Lots of shelving and parts storage is also important. Costco sells a heavy duty wire rack for less than $100, it is food grade so very high quality. It's adjustable shelves are perfect for storing multiple computers and parts. High qual caster wheels make it mobile. Can't find the part number or make/model, but I am pretty sure it is the only one they sell in thatprice range and sheer size. NCIX got a bunch of therm when they moved their Broadway location, I saw them there and asked where they got them. I then went to Costco as a guest with a nieghbor and picked one up. I just wish I had room for another one. I use Banker Boxes (cardboard file cabinets) for storing mobos that have heatsinks on them, perfect and cheap. A KVM is a must of you want to run more than one computer while working on another. Never enough room for more than one or two monitors, and they generate a lot of unwanted heat. I can run three systems at the same time on my bench, two via KVM to a CRT, and one to a small LCD. And still have enough room to work on a 4th! I also have a layoff bench that I can run two or three more systems, via another KVM and large CRT. Once I have a system buttoned up, I move it to the layoff table for any further testing etc. The layoff table is just behind my main systems' desk on a different circuit, and just got another 4 port KVM so I can access them directly from my desk. I mostly stand while working at the bench, which is why I like it so high. Kitchen counters are way too low for me, my back hurts when doing the dishes! A good stool is a must. Something that has an adjustable hieght and quite high at it's topmost is a godsend when doing delicate work or your feet are getting sore. Ideal bench hieght is just above your belly button, so you don't have to lean over hardly ever. You can raise the desk with blocks of wood. I got my stool for $30 at Outdoor Warehouse, and is a cheap POS but perfect for now. A better one is at Canadian Tire, the HotRod magazine stool for about $60 iirc -- want one! Expensive but best solution, is a drafting stool/chair. Have you ever noticed how often you must turn a case back and forth to get to screws and wires on each side of a case? I am constantly lifting and turning a system when working on it, forcing me to get out of my chair. So... For a future project, I plan to make a Lazy Susan for easily spinning a case around while working on it. I haven't locked down a plan yet, and may build it into the surface of the bench or just have it on top so I can move it out of the way when I am not using it. It needs to be lockable somehow so it doesn't rotate when you don't want it to. Lee Valley sells the rotating hubs, cheap and good quality with bearings. One of these ressesed into the bench with a plywood top and some more yoga mat material would be sweet. .
__________________ eVGA 680i SLI (A1) P31 Intel E6750 Conroe 1333 G0 SLA9V L723B134 | Scythe Ninja-B | Antec Tri-Cool 80cfm 2x1024MB Crucial Ballistix Tracer 8500 | 5-5-5-15 1066mhz @1.9v boot: 4x WD Caviar SE16 250gb SATA2 Raid-0 backup: Seagate 500gb 32mb SATA2 eye: eVGA 9800GTX+ SC 512mb 770/2.25ghz candy: Samsung 940B-HAS | X-Fi XMusic | Pioneer DVR-212D SATA juice: PC Power & Cooling 750Quad | Cooler Master HAF932 steering: Logitech G15 & G5 | E3D Pro/Momo Wheel | X-530's Last edited by Lithotech; August 23, 2008 at 09:52 AM. |
| Thread Tools | |
| Display Modes | |
