Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old July 23, 2008, 10:31 AM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Just a word of caution.
For anyone buying an Apogee GT its backplate can be a pain to switch from one motherboard to the next.
Might be worth running the system at load for a bit before trying or sticking the board int he freezer. Either way your liekly to loose some of the backplate pad.
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
Tags
guide , water cooling
