Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old June 14, 2008, 06:25 AM
Default L.F. How To Guide Sites for GA-P35-DS3R
Removed
Old June 14, 2008, 07:55 AM
3.0charlie's Avatar
Can you be more precise on exactly what you are looking for, or what is the problem?
Old June 16, 2008, 05:07 PM
3.0charlie's Avatar
I don't believe the DS3R allows for hot-swaps.
Use the purple SATA ports if you wish to run your Raptors in Raid 0.
If you are not oc'ing, leave the ram setting per SPD.
Unless you have a PCI-e SATA controller, all SATA components will be driven by the Intel Controller.
Old June 17, 2008, 12:47 PM
3.0charlie's Avatar
I don't see why you couldn't use 2x IDE drives on the IDE channel. Just set-up the drive jumpers properly (Master vs. Slave) and connect the Master drive at the end connector, while the Slave drive can be connected at the mid connector.
Old June 17, 2008, 02:18 PM
Aren't the IDE Connectors part of the purple sata connectors. In other words, if using Purple as raido, then no IDE.
Old June 17, 2008, 02:21 PM
3.0charlie's Avatar
Nope; the IDE and SATA controllers are totally independent. Where did you read that?
