Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 8, 2017, 01:42 PM
Mnpctech's Avatar
Default Custom Automotive Color Paint in Rattle Cans
Hey Gang, Looking for a specific automotive factory paint color to paint your case? I used ScratchWizard Rattle Can Paint to paint my Case Labs BULLET BH4 MATX case here, https://www.youtube.com/watch?v=Y5aPoIOBP9M
All you need to find the paint color is enter the Year, Brand, and Model of car here, https://scratchwizard.net/bumper_search/
(Use 3M Perfect-It III rubbing compound to remove any orange peel in the clear)
Old May 8, 2017, 08:50 PM
TRTW's Avatar
thanks for posting this. I could actually use a can to repair my Ford.......
Old May 9, 2017, 02:24 AM
KaptCrunch's Avatar
I find them rattle-cans need a paint to shaker to get use all of paint from the can otherwise hand shake can never empty the can all the gas is gone (pressure) before paint
Old October 23, 2017, 06:37 AM
Mnpctech's Avatar
agreed
Contrary to what paint manufacturers tell you, spraying your paint upside down to clear the nozzle will waste the propellant gas inside, which may resulting in lowering the air pressure later
Power supply fan rattle clone63 Power Supplies 10 April 22, 2014 07:00 AM
Automotive Air Filters jcmaz Off Topic 9 December 26, 2010 05:11 AM
Pump rattle? SugarJ Water Cooling 6 April 26, 2009 10:02 AM
Automotive Quality Paint in Aerosol BALISTX Cases 1 April 24, 2007 02:08 PM
Coolermaster is offering custom paint cdn_Madrach Reviews & Articles from the Web 3 April 1, 2007 04:56 PM
