Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 22, 2016, 11:30 AM
N.E.A's Avatar
Default How to upgrade my SSD to a bigger one without losing OS
Hello everyone. Currently I have a 50 GB SSD from 2011. It is in good shape it performs well until now. But it is so low on space. I only have around 1 GB of storage left which gives me headache every once in a while because it goes lower than that until I clean up the PC with CCleaner.
Is there a good way of migrating my OS and all the files on my SSD to new SSD?
Note: I have ubuntu installed on my HDD and I believe the boot file is not on the SSD itself. So I don't know if this changes anything about how to migrate the OS.
One last thing, which SSD do you recommend? I want to get something that is 240 - 480 GB.
Thanks in advance.
Gaming Rig:
Intel Core i5 2400
Asus P8P67 Pro
8 GB G Skill Ram
Gigabyte GTX 275
60 GB Adata SSD
2 TB WD HDD
500 GB Samsung HDD
Cooler Master HAF-X case
Cougar 700 watt PSU
Logitech G700s mouse
Asus Orion gaming headset
Owl Hunt: Tutorials, Trends DIY, How To, Top 10s
Old May 22, 2016, 11:43 AM
jalmir's Avatar
use ToDo Backup free, that's what I used to transfer my wife HDD to SSD. It's pretty simple.
Download free data backup software - EaseUS Todo Backup Free
A guide on lifehacker;
How to Migrate to a Solid-State Drive Without Reinstalling Windows
Itís hard to win an argument with a smart person, but itís damn near impossible to win an argument with a stupid person.
-Bill Murray
Old May 22, 2016, 01:54 PM
Lysrin's Avatar
This. Used it to clone everything on my laptop to new SSD at it worked great.
Old May 22, 2016, 03:07 PM
Soultribunal's Avatar
Thanks in advance.
Kingston makes some decent drives for the cost (I can almost always get a Kingston V drive for $99 / 240GB at my local CC).
They might not be top tier in terms of raw performance they get the job done for years and years.
PNY does have nice ones as well where you can find them.
-ST
www.realhardwarereviews.com
Old May 22, 2016, 04:21 PM
" I believe the boot file is not on the SSD itself"
1) it always helps to give full details about'one PC to get help.
2) I have used a few times "Macrium Reflect Free" to migrate OS to a new drive with succes:
Old May 24, 2016, 08:10 AM
Samsung 850 Evo's are great SSD's for good price. They also have software for easy migration but im not sure if it works on Ubuntu.
Old May 24, 2016, 10:21 AM
N.E.A's Avatar
Thank you all for your input. I will consider as Tyrann said either the Samsung 950 evo or maybe this one: http://www.amazon.com/Kingston-Digit...8&keywords=SSD
Both are reasonably priced and have good capacity.
Gaming Rig:
Intel Core i5 2400
Asus P8P67 Pro
8 GB G Skill Ram
Gigabyte GTX 275
60 GB Adata SSD
2 TB WD HDD
500 GB Samsung HDD
Cougar 700 watt PSU
Old May 24, 2016, 12:59 PM
Fudd Rucker's Avatar
I use macrium religiously. Simple and to the point.
I couldnt think of something snarky or interesting to put here this time around.
Old May 26, 2016, 12:01 AM
Trial Member
There are many programs can help achieve the goal. Just clone the OS to new SSD is enough. After migration, the previous will become a folder. You can delete it after you confirm the new cloned OS is well-worked.
Old May 26, 2016, 01:19 AM
Default clone ssd to a larger one
I recommend you use a free cloning software to clone SSD to a larger SSD without the need to reinstall OS or installed programs. when the clone is done, you can replace the old ssd with the cloned one.
Tags
how to migrate , low space , ssd
Bigger than 27? CMetaphor Display Units 17 May 28, 2014 03:14 AM
upgrade SSD to bigger SSD misterd New Builds 3 February 27, 2012 09:20 AM
So did anyone hear about HP's CEO losing his job Opeqa16x Off Topic 13 August 10, 2010 06:58 AM
DIR-615 Losing internet connection... Ironmonk Troubleshooting 8 November 16, 2009 09:50 PM
Amd Phenom we're losing 10%to 20% power xtreme1 CPU's and Motherboards 5 February 19, 2008 09:17 AM
