Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #31 (permalink)
Old May 1, 2010, 06:26 AM
gingerbee's Avatar
this to me is one of those things if you can't manage to do it with just about anything you have lying around then maybe you shouldn't be doing it at all. removing tim needs a video now. ok sure
  #32 (permalink)
Old May 1, 2010, 06:37 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Originally Posted by Pelt View Post
I was laughing so hard I was crying when I read MacJunky's post. But then I thought what if this kid takes this crap seriously....then I laughed even harder at the thought of him doing that stuff....that seemed like a better sentence in my head, now I'm not to sure.
QFT'ed and +1'ed.
Might be have been in poor taste MacJunky....BUT I was like: WTF?! Then I was like: ROFLMAO :)~
Anyways on topic:
99% alcohol + lint free cloth is how I do it.
I use the pea method for solid base coolers and the multi-line method for HDTs.
  #33 (permalink)
Old May 3, 2010, 04:49 PM
LaughingCrow's Avatar
Instructions for using Artic Clean on Artic Silver's website - PDF (last item):
Arctic Silver, Inc. - Instructions
  #34 (permalink)
Old May 3, 2010, 08:09 PM
poroporo's Avatar
I never have the appropriate things around me when I'm working, so I use Scott Towels or Q-tips.
It just works. Didn't even know Artic Clean existed
  #35 (permalink)
Old May 7, 2010, 09:22 PM
geokilla's Avatar
Ok the coffee filter I got from my friend feels pretty rough... Feels a bit like normal paper, but at the same time it doesn't. I guess I'm fine?
At worst, I can just use Q-tips I guess... Or just go to dollar store...
  #36 (permalink)
Old May 7, 2010, 10:10 PM
ZZLEE's Avatar
Default spose to be that way
The rufness of the papper acts like gental sand paper. If you lose the writing on the chip no RMA. But paper wont rub to much off.
If you want to get Extreem Look up Lapping a chip on youtube
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #37 (permalink)
Old May 7, 2010, 10:45 PM
I've been using kleenex to clean up thermal paste as long as I've been working with PCs. It's really not something you have to worry about.
