Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 19, 2008, 04:34 PM
Dashock's Avatar
i just use 99% isopropl alchol which you can get at loblaws for 1.99 and either a lint free cloth i got a lot of cloths from a computer show soo i just use that their verrry good and the isopropl works miracles takes it right off.
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old May 19, 2008, 09:58 PM
MacJunky's Avatar
Originally Posted by DK2 View Post
wth?
Originally Posted by paphman910 View Post
P.S. If I were you, I would not ejaculate on the cpu because the thermal paste for the cpu is different than the one for the chipset.
Originally Posted by Supergrover View Post
And Junky: WTF?
Originally Posted by enaberif View Post
Don't listen to Macjunky hahaha.
Originally Posted by MpG View Post
MacJunky - yet another casualty of the May two-four.
At least, I certainly hope so.
Can't I ever have any fun? How can you not find what I posted completely hilarious?
And yes, I am and was entirely sober. A little tired perhaps but sober.
I hope nobody missed my disclaimer at the bottom. >_>
Think I need my own thread for some amusing crazyness like this and other absurd things I have jokingly said. :P
Anyway, getting back on topic...
Old May 20, 2008, 03:07 AM
Dashock's Avatar
I found it Hilarious i had to read it over a couple of times at first i thought it was serious yu had me going ! lol
Asus P5Q-E
Antec Spot Cool
Logitech X-230
Old May 20, 2008, 04:57 AM
no_pulse's Avatar
At first I was like, "is this guy serious"? lol Btw ejaculate works well, a bit sticky, but works none the less. hahaha ;)
Thanks for the tips guys :)
enaberif,
You said the foam pad from the motherboard was abrasive, did you mean non-abrasive? Isn't abrasive the opposite of what you would want on the CPU or Chipset?
Old May 20, 2008, 05:55 AM
DK2 DK2 is offline
I didn’t get as far as the disclaimer.
Yep, rubbing alcohol works well, would even clean up MJ’s mess.
Old May 20, 2008, 09:31 AM
Rubbing Alcohol has to be at least 99% otherwise there is to much water content which you have to wait and let evaporate.
Old May 20, 2008, 10:14 AM
1Tanker's Avatar
I'm still using 70% and it evaporates within 2 seconds.
Old May 20, 2008, 03:10 PM
Supergrover's Avatar
I use 99.9% myself, I find the 70% leaves a residue
R.I.P.
  #19 (permalink)
Old May 20, 2008, 03:27 PM
here is a nice video (curtosy of NCIX) on how to remove thermal compoud and reapply it
YouTube - NCIX Tech Tips #11- Installing Thermal Compound
the other NCIX tech tip videos are pretty good IMO
  #20 (permalink)
Old May 20, 2008, 04:21 PM
You might wanna take a look at this: Best Thermal Paste Application Methods | best thermal paste application,thermal compound,thermal interface material,best practices | Benchmark Reviews Performance Tests
Also, I like to apply the paste, mount the HSF and take it off to check the coverage...and then re-mount according to how well the TIM spread.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
