Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old October 5, 2014, 10:41 AM
Shadowmeph's Avatar
Default Need a guide to run 3 pin cpu fan at full
I know there is a way to run a 3 pin cpu at full but I cannot seem to find it without cutting wires
Old October 5, 2014, 12:11 PM
ZZLEE's Avatar
The moutherboard header is 3 pin or 4 pin PWM ?
GELID Solutions CA-PWM 350 mm PWM Y Cable - Newegg.ca
4 pin PWM to 3 pin use this.
then in bios set fan speed.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old October 5, 2014, 12:21 PM
sswilson's Avatar
No settings in bios for it?
Old October 5, 2014, 12:34 PM
ZZLEE's Avatar
Ther is also 4 pin MOLEX to 3 pin adapters that will get 100% speed.
Plug anuther fan into the CPU header = trick it.
Old October 5, 2014, 02:21 PM
Bond007's Avatar
Set in bios, or use a molex would be the easiest.
Old October 5, 2014, 03:46 PM
Plug into a fan header other than the cpu fan one.
Old October 5, 2014, 04:04 PM
Shadowmeph's Avatar
this motherboard does have a setting for full speed plus others in the bios but it is 4 pin only I hate it because I am trying to strees test this Opteron 6234 chips but I keep getting the dam alarm that I am over 70c so I definitely need to do something to cool this chip
Old October 5, 2014, 04:22 PM
4 pins work on a 3 pin header. 4th pin is just PWM.
Old October 5, 2014, 04:28 PM
sswilson's Avatar
I think he's saying that the bios control is strictly PWM.
If that's the case, your best bet would be to just get your hands on some molex adapters. If you were local to me I've got a million of the bloody things left over from YL's. :)
Old October 6, 2014, 06:32 PM
Shadowmeph's Avatar
ok so I got pissed off with the trying to figure out the fan pin thing and ended up juryrigging a waterblock on the the Opteron ES chip and I have to say that really brought down the temps a good 10-15c .
I want to OC this chip but I am worried about other temperatures according to th HWmonitor tmpin 2 is 74 -94 running stock under full load with a single 95 I cannot tell that prime 95 is even running lol but that seem vry hot for what ever that is I know thta my cpu hasn't gone over 32c,
I did a I ran tpc using freq 3000 and ccore 1.1250 but for some reason instead of 3Ghz I get 4.5ghz when the system has a slight load and my temperature stays around 25 while gaming I tried prime and my system Blue screened after a few minutes but like I said that was at 4.5Ghz .
GTX670 with water block, full sytem or full loop Pabz0r545 Price Check 2 April 15, 2013 05:49 PM
Currious if anyone uses a TV guide Shadowmeph Off Topic 5 August 18, 2012 01:00 PM
Guide to Clean a SSD avrionis Guides & How-to's 6 December 30, 2010 07:27 PM
how do I get the tv guide in MP to work? Shadowmeph HTPC Systems & Software 7 August 21, 2009 07:38 AM
Evga X58 n I7 OC'ing Guide rjbarker Overclocking, Tweaking and Benchmarking 0 December 6, 2008 11:42 PM
