Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old June 5, 2014, 08:14 PM
Default Best way to ship my Rig?
I am moving 2,000 miles away and i cant bring my computer with me. what is the best way to ship it?
Old June 5, 2014, 08:57 PM
ZZLEE's Avatar
From Where to where.
air cooled or water cooled.
Air cooled remove graphics cards and large air heat sinks and RAM.
Do you still have the box the computer case came in ??
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old June 6, 2014, 06:11 AM
Bond007's Avatar
Remove aftermarket CPU heatsink, RAM (less of a concern), and any installed cards (GPU/soundcards/etc), and ship it in the factory case box if you have it.
Old June 6, 2014, 07:50 AM
Bungwirez's Avatar
Courtesy: Singularity Computers.
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old June 6, 2014, 07:57 AM
Dzzope's Avatar
bung has it..
From experience traveling throughout europe with my rig:
As said above, remove anything heavy.. Heatsinks, gpu's etc. HDD's are a must remove too, especially if they are in a caddy and not screwed in.
Put some card over the motherboard (I don't remove ram) And fill with large bubble packaging, enough to make sure nothing can move and if it does, it won't go far / bounce around.
Original box & packaging is a bonus but not a must. Just give about 2 - 3 inches clearance from the box and make sure again it cannot move.. Hard-case (like above) is Ideal.
Rig in my sig has made 3 trans Europe trips. Last one was rough enough to bash the box and break the packaging and dislodge a fan from it's mount (not the surround, just the blades) but everything still survived and no hard-case.. Monitor wasn't so lucky :(
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old January 31, 2015, 12:06 AM
What would you guys suggest if I don't have the factory case box? Just try and find one that fits and put some styrofoam (or something else that is protective) around it?
Old January 31, 2015, 01:16 PM
ZZLEE's Avatar
A large enough box. If you can find foam from an eletonic component that someone if throwing out or rigid foam insulation from a building supply store. Building supply store may have packing bubble rap also.
Take out Graphics cards large heat sinks hard drives if they are loose at all.
when you get it to new location go over everything carefully. put it back together.
Old January 31, 2015, 04:53 PM
Bond007's Avatar
make sure everything that is attached 90 deg to MOB is taken out
Old January 31, 2015, 07:46 PM
At my last job when we bought used equipment from a vendor in the states, they usually encased the equipment in an antistatic bag then used expanding foam to create the insulation. Get a large heavy duty box, create a layer on the bottom for it to rest on. Place rig encased in a bag (with any parts removed as the above) in the center then use expanding foam to insulate the sides till it fits snugly. Fill in the top as needed. Goes without saying, you need to wait for the foam to harden at each stage!
ship battles cmac79 Gaming 5 March 12, 2011 04:34 PM
XFX Jumps Off GTX 480 / GTX 470 Ship SKYMTL Press Releases & Tech News 60 January 30, 2011 03:46 PM
HAF X for $179.20 CDN with $10 ship at NXSource.com Smoothie Cases 0 June 16, 2010 07:10 AM
Did the grills just ship ZZLEE Suggestions & Feedback 1 April 19, 2010 08:59 PM
