Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old April 23, 2014, 10:12 PM
Default Eyefinity Setup
I have an older refurb hp desktop that I'm using as one of my development workstations and have been piddling away with a single 22" 1680x1050 monitor and just picked up 2x 19" 1440x900 monitors to use in a triple monitor config, and just dropped in a spare GT210 I had laying around.
Turns out the onboard video is disabled when discrete graphics cards are installed, I'm not too keen to dump a lot of money in this to get it working, as it's only a Core2 Q8200 with 4GB ram and a 120GB SSD.
Before I jump the gun and purchase the parts, here's what I'm looking at and from my research should be all that I need to get things running in eyefinity for the desktop:
GPU: Buy the VisionTek Radeon HD 5450 512MB GDDR3 Video Card at TigerDirect.ca
Adapter: Buy the StarTech Mini DisplayPort to DVI Active Adapter at TigerDirect.ca
What I intend to do is run DVI -> VGA adapters to the two 19" monitors (they only have DSub connections) and MiniDP->DVI to the primary 22" monitor.
Thanks in advance
- Nerf
3 way eyefinity setup? FLATLANDRIDER New Builds 11 April 12, 2012 07:05 PM
Making my Eyefinity Setup better/advice Rikan S-087 New Builds 3 May 9, 2011 07:34 PM
Eyefinity setup or U2711? Asad_A203 Display Units 0 May 6, 2011 03:49 AM
Eyefinity setup question cul8erppl Video Cards 6 November 2, 2010 09:36 PM
Eyefinity Setup lcdguy Display Units 8 August 3, 2010 08:24 PM
