Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old January 23, 2014, 07:24 PM
sakage.shinga's Avatar
Default Setting up MPC-HC
Hi guys,
I'm trying to find a decent guide to setup MPC-HC on my HTPC. I found one that uses Haali, LAV filters, and madVR, but the resulting player won't allow me to skip forward without massive slowdowns and system freezes.
Here's the guide: Media Player Classic Home Cinema (MPC-HC) and MadVR Setting | Juan2Geek
Keeping my HTPC specs in mind, which guide would you guys recommend? Or should I just use the stock MPC-HC as is?
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 23, 2014, 07:52 PM
Why bother just use XBMC :P
Old January 23, 2014, 08:14 PM
lowfat's Avatar
Any specific reason you aren't using the filters that come w/ MPC-HC? What kind of videos are you playing where you need to use these filters? Filters like MadVR are IMHO completely unnecessary. A person isn't going to notice the different between it and other filters. Haali isn't a great MKV splitter IMO either.
If you don't want to use the MPC-HC stock filters you might as well use LAV for splitter, audio, and video.
But like enaberif says, I'd personally just use XMBC. It can do everything these days.
Mael
Big Lian Li
Forever Alone
Old January 23, 2014, 08:32 PM
Hmm, any decent guide/tutorial to setting up XBMC?
Old January 23, 2014, 08:57 PM
lowfat's Avatar
It really isn't hard to setup. Install XBMC. Go to videos, files, add source. Add your movie folder. Make sure you set it to movies as the source. Do the same thing for TV shows.
Mael
Big Lian Li
Forever Alone
Old January 23, 2014, 10:17 PM
Shadowmeph's Avatar
yes XBMC is the best I have used f\so far , you might need to do the tweak so thatyour remote controls green button loads up XBMC instead of windows media center other then that it is just like what has already been said.
I am almost debating on just using the XBMC linux but when I tried it in virtualbox it wouldn't load into the mediacenter but to the desktop , there probably is an easy tweak to fix that though.
Old January 26, 2014, 02:21 PM
Wow yes XBMC is great! So much more user-friendly than MPC-HC. I'm still keeping MPC around though since it makes a great standalone video player.
Old January 26, 2014, 03:00 PM
sswilson's Avatar
I've been using the paid version of the android Universal Remote app for controlling XBMC, and have been pleased with the outcome. I believe there's a free XBMC remote but for some reason I preferred the Universal Remote.
Old January 26, 2014, 03:26 PM
lowfat's Avatar
Constellation is probably the best XBMC remote for iOS or Android. For a windows 8 tablet / laptop XBMC Commander is a decent metro app for controlling XBMC.
Mael
Big Lian Li
Forever Alone
Old January 26, 2014, 03:36 PM
sswilson's Avatar
From what I can tell there is no Android version of Constellation.
Setting up a SSD pcmike Storage 5 December 23, 2012 09:15 AM
Some help setting up? mikellini HardwareCanucks F@H Team 19 November 3, 2011 02:34 PM
Setting FAH martin_metal_88 HardwareCanucks F@H Team 6 September 28, 2009 08:16 PM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
