Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old October 22, 2013, 03:48 AM
i just use the latest WinPE 4.0 from MS provided with the Windows ADK
it has everything you need built in to the command line to capture an image to a network or external drive to redeploy to a new drive. only problem is, you need to take an image, and apply the image, no direct copy
I had posted some information here before
is there a guide for ghosting/clone/imaging a new win7 install
Old December 1, 2014, 08:44 PM
mello_newf's Avatar
I use Paragon Hard Disk Manager and it's super easy never had a issue.
Need help with XFX Warranty Transfer Tainger Troubleshooting 3 April 21, 2012 02:17 PM
Post your external drive enclosure transfer speeds. Cardboard box with DSL Storage 1 June 28, 2008 06:57 AM
