Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 3, 2013, 01:11 PM
snef's Avatar
Default plasti-dip your motherboard
Hi
I have nothing to today, why not painting a motherboard
bought 2 can of white plasti-dip and 3m masking tape
first
chose a motherboard
I have a spare motherboard on a shelf, a Gigabyte GA-H77-DS3H, if I burn it, to bad, go to garbage
tape all connector, hint: use 3m tape, a way better (the Green one)
after one coat,
wow I really like the results
some pics
and yes, easy to remove if you put enough layer
I have coat, 2 first are thin and 2 last are thick
I will try to do a tutorial, its very simple
Old August 3, 2013, 01:20 PM
IRQ Conflict's Avatar
Pretty Sweet. Just need some white/blue sleeving now.
Old August 3, 2013, 01:23 PM
sswilson's Avatar
Looks great! Especially on an already white test bench. :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old August 3, 2013, 01:53 PM
lowfat's Avatar
What about the mosfets on the board? I think they might get a tad warm.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 3, 2013, 02:21 PM
snef's Avatar
Thanks
i let running for more than 4 hours with a 40% cpu usage and vrm stay cool, the only parts running a little bit hot is the liitle rectangular cube aroud the cpu (i dont know what is, im relly noob in electronics)
and this mobo dont have any heatsink, maybe dont need it loll
any other mobtherboar have heatsink, just tape it and no VRM or mosfet heat issue
seriously, i did it because i have nothing to do this morning and want to do this for a long time
this motherboard return to the shelf in the garage, and maybe never see 12v anymore
i want to know if its possible and now i know
the bench is my current project but with a Maximus VI Formula, for sure armor painted white
Old August 4, 2013, 09:22 AM
snef's Avatar
Update on testing
Very close to 20 hours of testings with 40% cpu usage
And no heat issue, no stability issue, work at 100%
ambient temp today is 29c in my office
all vrm still cold to touch, only thing with a little bit of warm is rectangular cap around cpu, only warm not hot
Its a h77 chipset and i use a i3-2100, no overclocking, use intel gpu, all stock
Keep in mind this mobo dont have heatsink on vrm/mosfet, thats why i painted vrm/mosfet
If you paint any motherboard with a heatsink, you will not have any vrm heat issue because you will tape the heatsink/vrm/mosfet
anyway mine are painted and i dont have any issue
Lollll someone saw my pics with plasti-dip mobo and already sold it in a build i will do for him
He wants it for a christmas gift lolll
Old August 4, 2013, 09:51 AM
KaptCrunch's Avatar
good show Snef just don't use silver color or any metal colours
Old August 4, 2013, 02:44 PM
NyteOwl's Avatar
As this is an insulator the temps you should be worried about are those under coating not above it. If it's cool on the outside, that means the heat is being held in, ie next to the components. It may be ok but it's not something I'd care to try except maybe on a low power system used mostly for e-mail and web browsing.
BTW, should have taped off the CMOS battery too in case it needs changing or removal.
Obsolescence is just a lack of imagination.
Old August 4, 2013, 04:07 PM
snef's Avatar
Plasti-dip do not isolate enough
Specially on vrm
Before painting, i run a test and vrm stay cool( ok warm not cool)
Same thing for cap, theyre same temp as before,
They are exact same thing with plast-dip
Plasti-dip do not conduct heat but im sure it not isolate enough for that
And i toke a menute to touch under the board and same thing , cold to warm, not hot
Only the rectangular cap is warm to hot, but i remove plasti dip on these
Same thing on battery, i remove it on battery and attery holder
Old August 7, 2013, 03:04 PM
BrainEater's Avatar
I'm a little surprised you are having no heat issues.
I've painted PCB's before , but never like that . It looks really good !
I might have to try this out !
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
new motherboard + refurbished motherboard kalvinjones Troubleshooting 0 May 14, 2012 11:44 PM
i7 920 & Motherboard which to keep trayton CPU's and Motherboards 9 January 30, 2011 10:43 AM
H67 Motherboard? JBM12G CPU's and Motherboards 13 January 28, 2011 09:27 PM
Need a new motherboard(AMD) Dnabb10 New Builds 11 January 26, 2011 10:41 AM
[WTB] S775 Motherboard and I7 920/930 cpu + x58 motherboard Table21 Buy/Sell & Trade 6 May 22, 2010 10:23 PM
