Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old November 28, 2014, 01:08 AM
Trial Member
I would love to try this on my upcoming build and most likely do but could anyone give me some good advice/tips , because i dont feel like going and buy a new board because of this process failing on me.
  #22 (permalink)
Old November 28, 2014, 06:00 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Mask off the areas you don't want sprayed. I'd also recommend masking off the MOSFETS as well due to the aforementioned heat issues.
Also, an EVEN spray is key. Try it on a piece of cardboard first so you are see the spray pattern and whether or not you are able to actually attain a consistent plastic depth.
  #23 (permalink)
Old December 1, 2014, 08:42 PM
mello_newf's Avatar
I so want to try this on a old test bench board I have
  #24 (permalink)
Old March 8, 2015, 12:22 AM
This is a killer idea for a game server that I have been wanting to set up on my LAN network cart
17-860 @3.99Ghz // 12GB DDR3-1866 // Zotac GeForce GTX 970 // 512MB SSD
  #25 (permalink)
Old March 13, 2015, 08:07 AM
For those wondering, heat probably wouldn't be an issue. I've been running boards, on air with Dragon Skin, and that is a great deal thicker than plasti-dip. It doesn't seem to cause any issues even when the volts are above stock. I'm going to try plasti-dip on a motherboard, might actually be easier.
new motherboard + refurbished motherboard kalvinjones Troubleshooting 0 May 14, 2012 11:44 PM
i7 920 & Motherboard which to keep trayton CPU's and Motherboards 9 January 30, 2011 10:43 AM
H67 Motherboard? JBM12G CPU's and Motherboards 13 January 28, 2011 09:27 PM
Need a new motherboard(AMD) Dnabb10 New Builds 11 January 26, 2011 10:41 AM
[WTB] S775 Motherboard and I7 920/930 cpu + x58 motherboard Table21 Buy/Sell & Trade 6 May 22, 2010 10:23 PM
