Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old April 1, 2013, 01:42 PM
BrainEater's Avatar
Default Thermal basics : a.k.a. What thermal paste.....
This is a basic explanation of heat transfer , and how to make your cpu coolers etc. work more efficiently.I'll try to avoid the maths , but it's a complicated subject so bear with me.
This is a work in progress , as I think about it.
Lesson #1 : The basic parts of a thermal system : The hot part and the cold part....Heat always goes from hot to cold.
The entire universe by it's very nature is constantly decaying into heat.Heat is abundant.
"Cold" is the absence of heat . You almost always require an input of energy to make "cold"....The 'net' energy always increases the 'heat' in the universe.
(Yea , we are waaaaay past simple I know..)
So back to cooling your CPU :
Lesson #2 : "Heat" is energy . Like any other energy source , it needs to be conducted.....Some pathways are better than others.
In the case of cooling a CPU , The heat moves from the CPU to the heatsink , and is conducted by the materials of both.(Ceramics and metals) .
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old April 1, 2013, 01:46 PM
BrainEater's Avatar
Lesson #3 :
The most important part in a simple heat transfer like CPU to heatsink is the conduction path.Usually metal-to-metal.....Soooo , the important bit is "Surface area" .You want as much metal on metal contact as you can get.
There are a couple things that affect this ;
- 1 : Flatness.
- 2 : Smoothness.
1:
Flatness means exactly that...Planar uniformity...."Flat" .....warped heatsinks are no good !! , on the same token , warped CPU's are bad too !
This is why 'lapping' works . "Lapping" is designed to make things flat....nowadays we can use milling machines to do the same , but the bottom line is this ;
If the CPU and heatsink are both truly flat , they will have more surface area for conduction.
2:
"Smoothness" is basically the grit of sandpaper you used to make it 'flat'.
'Scraped flat' is a lot different than 'Optically flat'.....Once again we are just increasing the suface area.
BrainEater's Avatar
Lesson #4
T.I.M. aka 'thermal interface material /gooop/thermal paste/etc'.....is the last .1 percent of the equation in the whole surface area thang.It's designed to fill the teeny scratches left from the "smoothening"
I assure you , optically flat/smooth heat paths need no tim.Skin oil would do it.
Thermal paste really isn't designed to fill large gaps.
Lesson #5
Clamping pressure !!!
This is an often overlooked part of the equation . CPU clips are spring loaded for a reason.
Commercial semiconductors that require heatsinks are ususally done with a torque wrench....The 'compression' , once again increases surface area.
Always make sure things are clamped down , and even pressure is better than high pressure.
Old April 1, 2013, 02:39 PM
BrainEater's Avatar
Lesson # 6 .
Interfaces.
Every time the heat has to move from one material to another (an 'interface' ), there are losses . In the case of CPU's , the heat goes from silicon to ceramic to metal......then you mount your heatsink.
This is why "De-lidding" / "IHS removal" works . You are eliminating 2 'interfaces'.
Lesson # 7 ( ....and this is probably the important one !)
90% of the time , a basic off-the-shelf cooler will work ! No fuss , no bother !! Here's the thing : They have been over-engineered twice.
Unless you are trying for major OC's / etc.....You don't need anything else.Things like expensive heatsink compound are really a waste.
Unless that .01 percent matters to you of course.
That will be my last post.....the advanced stuff , for those who DO want that extra bit.
Old April 2, 2013, 03:48 PM
BrainEater's Avatar
More stuff : (The advanced bits)
Materials/conductivity/etc
As I've said earlier , the "conduction path" for heat is the key , but some materials are better than others . A copper heatsink works faaaaaar better than an aluminum one . And a silver one would be better than copper.
Start here :
Thermal conductivity - Wikipedia, the free encyclopedia
It's at this point we're into custom engineering.
I'll throw up a bunch more links , and I would welcome critique from everyone !!
Old April 2, 2013, 04:11 PM
IRQ Conflict's Avatar
Just a minor niggle, but you have that backwards. The universe will eventually reach equilibrium and suffer what is known as heat death. So, entropy leads to a serious cold rather than an epic inferno.
Old April 3, 2013, 02:59 PM
BrainEater's Avatar
Yep , you're right.....that's 'eventually' tho......right now the universe bleeds off as heat.
And more importantly , right now , all (mechanical ?.../ driven ? ) cooling on the planet earth is done with net gain on the 'heat side'.
Old April 4, 2013, 03:46 PM
I have been looking into delidding my 1090 but I'm prepared to replace it if things go south. Interested in trying? I still have to make sure my block will work without the lid tho... clearances etc.
cool post tho. cheers.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 5, 2013, 02:13 PM
BrainEater's Avatar
Thx bud !
I'm just trying to organize a decent set of links.
It's 'technically' a very complex subject , but it's not difficult when explained , that's my hope with this thread....
Old October 23, 2013, 01:38 AM
Any reason why copper is used instead of silver on heat sinks? (material cost i guess)
What thermal paste for my GPU? Polygon Video Cards 9 December 12, 2010 01:47 AM
GTX 580 thermal paste mikellini Video Cards 13 November 17, 2010 11:37 PM
Thermal Pad vs. Thermal paste? RainMaker Troubleshooting 2 April 13, 2010 07:13 PM
Thermal Paste r0k0 Overclocking, Tweaking and Benchmarking 11 February 15, 2010 11:53 PM
Thermal Paste? Luckk Air Cooling 16 November 24, 2009 08:57 PM
