<~----> Taking the cover off the Windforce x3 7970. - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 15, 2013, 02:56 PM
Trial Member
Default Taking the cover off the Windforce x3 7970.
Hello forum, im modding my case and i want to paint the black plastic on the gigabyte 7970.
The problem is i cant seem to find out how to get it off, and im to scared to fiddle around with it risking breaking something on it.
so if any one knows some instructions or some pics, i would be a happy modder.
Thanks.
Old March 17, 2013, 07:07 PM
great_big_abyss's Avatar
Not too sure about the windforce in particular, but sometimes you need to remove the entire heatsink from the card itself in order remove the screws attaching the shroud to the heatsink.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old March 22, 2013, 08:52 AM
Thanks.
I won't take the chance of damaging the 7970 card.
Old March 22, 2013, 09:19 AM
Not that it really matters anymore, since the OP hasn't come back since, but for the sake of argument, you can't really do too much damage by removing the heatsink from the video card, as long as you're careful. Basically just remove all the screws holding the heatsink to the card, then slowly wiggle the heatsink loose (it will be stuck to the GPU by the TIM) before carefully removing it, then unplugging the fan header(s). Once it's off, you can remove the screws holding the shroud to the heatsink. As far as damaging the card itself, you can't really do much harm as long as you're careful. Make sure to use a soft cloth to clean the TIM off the heatsink and the GPU chip itself (I really like those cotton pads that girls use to take make-up off their faces). Make sure not to scratch the PCB or the silicon chip, and ensure that the thermal pads on the RAM chips stay intact. Try not to touch anything (except the sides of the card) with your oily fingers. Make sure to ground yourself often to reduce the chance of static shock.
The biggest problem with removing the heatsink from your card is it will probably void the warranty. Now, this is no guarantee that manufacturers will automatically reject a warranty claim, but you do take a chance that they won't fix/replace your card should they find out that the heatsink has been removed. There are a few ways they can find out, chief being the sticker over one of the screws (that says warranty void if removed - not all cards have this sticker) and the type of TIM being used (if their factory uses grey TIM and you've replaced it with white TIM, it's a dead giveaway).
[FS] 2 XSPC Razor 7970 full cover waterblocks. Syl66 Buy/Sell & Trade 12 September 18, 2012 08:36 PM
[FS] Gigabyte Windforce OC Radeon 7970 Eluder Buy/Sell & Trade 5 August 16, 2012 08:21 AM
Windforce 7970 vs Windforce 670 JoeOnePack Video Cards 8 June 8, 2012 08:27 AM
Buy Gigabyte 7970 Windforce for $600 or wait? bconngeminil.c Video Cards 8 January 31, 2012 09:57 AM
Gigabyte to Introduce HD 7970 Windforce 3x, Clocked to 1GHz SKYMTL Video Cards 0 January 8, 2012 08:03 PM
