Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old February 5, 2013, 06:04 PM
Default Where can I make cheap custom cutouts for spray painting?
Hey guys as the title suggests i want to cut out some stuff on something durable to use as a stencil.
Say i want to make the nvidia logo and spray paint it onto my case
What material would i use and where could i get it done in the ***US***
Old February 5, 2013, 06:23 PM
ZZLEE's Avatar
Goto your local business supply store STAPELS or the like.
file folders
cut your stencils out of the thin cardboard.
or Dollar store and bristle board,
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 5, 2013, 06:57 PM
Will the thin cardboard be good for a stencil? I don't want any fibers causing an imperfect logo if you get what I mean.
By file folders, you mean make the stencil out of file folders?
Will Staples do the cutting for me, and is it affordable?
Old February 5, 2013, 07:17 PM
I use bristol board from dolarama, and use a hobby knife to cut my designs out.. I normally either draw them out, or print them out from on line, then serculey tape it on the bristol board, then cut them out.
As long as you make the cuts clean, theres no problem. Also, paint goes a long way, as long as you dont coat the thing too much, you wont have any leakage/drip problems. Another way around this is to never paint vertically. lol
Bought Items:
GTX 470 from ZeroFlux
Swiftech MCW60 from chubaka
Sold Items:
Steelseries Siberia V2 to MAK
Zalman Fan Controller, OCZ Mem Fan Funguseater
Current system:
i5 2500k @ 5 Ghz
Zotac gtx 470
8GB Corsair Dominator ram @ 1333
Old February 5, 2013, 07:29 PM
IRQ Conflict's Avatar
Not painting vertically is good advice if your a novice. Use a temporary spray tack on the side of the board you plan to attach to the case. Use a flat clear coat to spray around the edges, let it dry then apply the colour(s) you want. That should ensure a nice clean line.
Use two or three coats of paint rather than one or two heavy coats.
Edit: You might want to brush the clear coat on to make sure is seals off the edges properly.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old February 5, 2013, 10:21 PM
dustin1706's Avatar
If you are looking for a service to cut you a stencil, just google "custom stencils" and you will come up with a lot of places. Most of them require you to request a quote, but expect it to be $50+ for a standard laser cut mylar stencil.
If you are doing a stencil small enough to fit on a piece of paper, just print it out on photo paper and cut it out with an exacto knife. If you need to do a large stencil you can use a free online service like blockposters.com to split an image into 8.5x11 sections, print those out and tape/glue them to a piece of posterboard/bristolboard and then use an exacto knife to cut it out.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old February 6, 2013, 06:33 AM
Ok. I will ask the guy at Staples what kinda material to use as a cutout. I would X-Acto the design but I really want a super clean cut and I usually go for edgy and intricate designs.
What does painting vertically do?
Old February 6, 2013, 10:40 AM
vertical, paint will usually run a bit especially if you use to thick a coat. You could also just use a good painters tape, guys who do motorcycles pinlines and such use this, and thier "work" is by far exteremely precise. You could also go to walmart, they sell cutting boards made of very tough see through plastic they are 2 in a pack for like $7 this way here you can get a reusable stencil if you so desire. But cardboard or bristle board works very well.
Old February 6, 2013, 06:05 PM
Hooded's Avatar
A hard thin plastic about 1/32" thick, would be the best material for making a re-usable stencil. This type of material can be cleaned. And will produce a better edge than bristol board. I have also used .015" or .010" brass shim stock for stencils. These could be cleaned with a thinners and still cut with an exacto knife.
Custom painting ASUS p67 Sabertooth TUF Motherboard Mnpctech Off Topic 4 June 20, 2011 10:03 AM
Spray painting your car? Tips? jcmaz Off Topic 23 August 5, 2010 03:35 PM
[FS] Custom Ruby NZXT Guardian 921 ATX Mid Tower Case CHEAP!!! kyle_L Buy/Sell & Trade 9 October 20, 2009 01:53 PM
spray painting motherboard expance Cases 9 May 19, 2008 07:47 PM
