Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old April 23, 2008, 03:55 PM
cmac79's Avatar
Default messy wires
noobish question i know but im just startin all this fun stuff lol. while waiting on funds to do my pc up i lil better,i decided to mod my case a lil so far i got the window put in and lights and a cpl more fans and never cost me nothing so hopin to stay that way lol.first what can i do to clean this mess up lol
and second anyone got any other lil cool things to do just to make shit look cool that won't cost nothing lol(im not cheap just moneys tight at the moment lmao)
thanx i love this site its alway there for my noobieness lol
Old April 23, 2008, 04:04 PM
Eagle Eye's Avatar
Get the dremel out and start cutting slots in the back to route those cable behind the other side panel if you can. If not just drill through the rivets and find a large enough screw to rethread the hole and you're set.
Old April 23, 2008, 04:41 PM
sswilson's Avatar
You can also check out the dollar store to see what they've got in for "wire management". You can pretty up your wires on the cheap if you can find some plastic wrap for the wires (it's a coil that goes around wires).
Old April 23, 2008, 07:01 PM
encorp's Avatar
Is this backwards land? hehe, that case opens at the right with the board on the left!
Old April 23, 2008, 07:09 PM
cmac79's Avatar
yea i thought that was a lil weird to when i first got it lol....thanx for the answers guys will look into those things
Old April 23, 2008, 08:12 PM
DK2 DK2 is offline
The simple method is to just use tie-wraps and pin it all to the back of the case as much as you can.
Old April 24, 2008, 04:24 AM
Eagle Eye's Avatar
Is that a generic PC case or a Dell invention? It doesn't even follow the ATX spec.
Old April 24, 2008, 08:11 AM
cmac79's Avatar
its an HP
Old April 24, 2008, 04:57 PM
BrainEater's Avatar
Actually it's right side up....cases that open on the left are upside down.
And it does actually look like ATX , it's just upside down.
FYI ;
The ATX spec , a modification of the AT spec , was not designed for vertical use really....It's from the IBM PC days when "Desktop boxes" sat flat on the desk.
If you flip an AT board vertically , in a case that opens on the left ,with the cards I/O ports to the back ,(video,sound etc) , the cards will be upside down ,as in most cases .However ,from a thermal management standpoint , the cards should be right side up to take advantage of 'convection cooling'.
Convection cooling is becoming less important however , as cards are increasingly coming with fans.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old April 24, 2008, 05:32 PM
Eagle Eye's Avatar
If you think about the amount heat being produced by video cards, chipsets and CPUs throw a fan into the mix and you have a Convection Oven
Fresh PC baked bread now coming soon to your local grocery store.
EE
