Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old December 5, 2012, 11:31 PM
dustin1706's Avatar
This is very doable, but I am curious what your scenario is that you need to turn on the pc remotely...?
What you are looking for is a remote momentary switch. You don't want the receiver to supply any voltage, you just want it to momentarily short out the power pins on your mobo. Please don't use a switch that provides any power. A remote switch that provides power would be used for something like tuning on case lights or fans remotely either directly or via a relay.
Excuse my quick and terrible ms paint diagram. Basically just give it 12v input from any molex and then T the momentary outputs into your existing power button wires. This will allow you to use the remote or the power button on the case.
12V Momentary Remote Control 0V Output Switch RP11 | eBay
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old December 6, 2012, 12:03 PM
eric31593's Avatar
Hey thanks! I bought it and probably have the time to hook in up in the next week or so and post again with my results.
Starting ALL over Malam Troubleshooting 19 November 6, 2010 07:30 PM
starting a computer bussiness smithrmark Off Topic 3 June 21, 2010 07:07 AM
Computer not starting up properly Gooses Troubleshooting 10 May 29, 2010 01:27 PM
Computer running not starting up.... Hail Ceasar Troubleshooting 4 March 26, 2010 08:16 AM
Starting Έρεβος Safearus Case Mods, Worklog & Gallery 12 September 17, 2009 02:01 PM
