Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old March 16, 2008, 09:26 AM
CMetaphor's Avatar
Quadfather
DO NOT use a compressed air can to clean out the dust from a case when your face is inside.
DO NOT
Apply thermal compound with a small paintbrush
DO NOT try to post your system with 12v ATX plug stuffed beside your 20-pin powersupply connector on your motherboard to get the nessesary 24 pins
DO NOT check the cfm rating of a vantec tornado by sticking your finger in it while it on!! (stitches ensue )
  #22 (permalink)
Old March 16, 2008, 09:57 AM
Originally Posted by v0maru View Post
if i have carpet everywhere ,
where do i stand then?
Stand in barefeet no socks.
Thats the trick.
Same situation here I do it ALWAYS!!
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
  #23 (permalink)
Old March 16, 2008, 10:17 PM
Moneyless's Avatar
Updated again! :)
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
  #24 (permalink)
Old March 17, 2008, 01:47 AM
tomorrow i will be build my first mobo
this has helped alot
so far i have only taken a computer apart and also only know how to do upgrades such as ram and harddrives and videocard. The only thing i havent done is installing a CPU and the HSF
any advice is welcome
  #25 (permalink)
Old March 17, 2008, 02:19 AM
RTFM
  #26 (permalink)
Old March 17, 2008, 09:58 AM
Cardboard box with DSL's Avatar
If you need to drink while doing something (ie taking apart a laptop, which can be very time consuming if you are careful) use a child's sippie cup thingie. The cups you give to babies, so that they dont get juice everywhere...
  #27 (permalink)
Old March 17, 2008, 11:35 AM
Dont put the side panel back on the case untill at LEAST 20 mins after you "think" your done installing everything, overclocking, or benchmarking.
unless you dont mind having to take it off and put it back on over and over again ;)
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
  #28 (permalink)
Old March 19, 2008, 07:06 PM
Il Duce's Avatar
Do:
-Make an attempt to learn how to build a pc (read online guides, past posts, motherboard manual, and more!)
-Always think of all the problems you can run into with your specific part combination (e.g. google your motherboard model and video card with keywords: problems, issues, and incompatibility)
-Make a specific list of what you'd want in a pc before requesting someone to make you a list of parts (e.g gaming at 80fps on high resolutions, e-sata, overclocking, Home Theatre capability, and etc.)
-purchase your parts at a local shop since it will be easier to exchange and refund unless you're the most patient person in the world
Don't:
-Rely on a forum as your tech support for your all your problems with parts... the manufacturers have a knowledge base, faq, and a phone line to address your issues!
-Do anything fancy until you've confirmed stability and performance with memtest and the usuals
-Assume building a pc is easy. It requires a lot of dexterity and a lot of time during your first build.
-Insult others for not responding to your "Hardware Problem Related" post in 2 minutes
-Ignore past posts with similar problems and hardware (THE SEARCH BUTTON EXISTS FOR A REASON!!!)
My points are focused on the minor still from highschool or junior high because we know there are more kids on the internet than adults, right?
  #29 (permalink)
Old March 19, 2008, 10:46 PM
Moneyless's Avatar
Updated yet again.
"I hate broccoli
-Deadpool
  #30 (permalink)
Old March 20, 2008, 04:23 PM
Supergrover's Avatar
I disagree, while being able to return a part quickly is a plus paying the surcharge that you are going to pay isn't worth it. Do your homework before you buy, then take the money you would have paid to a local shop and put it toward better parts. While there is a few exceptions most local stores are 20-40% more. Plus if you are like me any of the local shops are complete idiots. ( No you Fing moron SDRAM is not faster than DDR)
R.I.P.
Building another rig! Kassela Troubleshooting 5 March 17, 2008 10:14 AM
Case building Materials chibi_man Cases 3 September 18, 2007 07:37 PM
Building a dedicated Folding machine Gav HardwareCanucks F@H Team 38 August 27, 2007 10:35 AM
1st Post Building AMD budget pc J2TheROC CPU's and Motherboards 4 July 13, 2007 10:36 AM
Building a new rig, need help(im new) NoobLordSpud CPU's and Motherboards 22 July 10, 2007 07:53 AM
