Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old January 4, 2012, 03:37 PM
Default Tests to do?
I am planning to build PC soon in the near future and was wondering what runs and test should I do to make sure everything is running and not defective.
For example, I know the so ever popular PRIME95 that Linus use to check RAM and CPU stability and such. Are there programs to check other components? (GPU, DVD driver, PSU, MOBO, etc) or how would you usually check if they are working 100%?
Old January 4, 2012, 03:47 PM
Furmark is a good stability tester for video cards as well as the 3DMark series of benchmarks.
Old January 4, 2012, 03:57 PM
SugarJ's Avatar
Check the utilities in this thread: Overclocking tools of the trade
The 2nd section of the list are programs used to test stability. I prefer OCCT myself, as it has a built in LinX and Furmark test.
Old January 4, 2012, 04:51 PM
Thanks for the quick reply guys, and SugraJ thanks. Those links look very helpful.
Tags
program , software , tweaks
Prime95 tests fail CroXtreme Troubleshooting 18 May 25, 2011 07:17 AM
Funny tests ADay2Long Off Topic 14 April 18, 2011 07:25 PM
pcworld.fr tests 22 modern gpu's _dangtx_ Reviews & Articles from the Web 6 July 14, 2010 11:36 AM
SSD damage / failure tests? shaw Storage 18 April 1, 2010 07:29 PM
HDD Tests miggs78 Troubleshooting 4 January 18, 2010 11:57 AM
