-   Guides & How-to's (http://www.hardwarecanucks.com/forum/guides-how-tos/)
-   -   How to run CHKDSK on linux? (http://www.hardwarecanucks.com/forum/guides-how-tos/46019-how-run-chkdsk-linux.html)
fireXtract August 30, 2011 08:51 AM
My family's laptop has crashed with the bluescreen and it says to run chkdsk /f but i cant because the file is on the broken hard drive so i installed UBCD onto a USB and opened parted magic.
I put the exe file in a custom folder and tried to run it but it doesnt let me run it. is there any other way to run chkdsk?
fireXtract August 30, 2011 09:37 AM
Oh and i dont have a CD drive
MacJunky August 30, 2011 09:41 AM
Linux and Unix do not have a program called chkdsk. It is called fsck.
And provided the distro you are using has man pages, you can find out about any commands you are interested in by using the man command.. as such:
man fsck
enaberif August 30, 2011 09:43 AM
There is no chkdsk in linux.. I mean there is a equivalent but I don't recommend to use it.
Your better off using your Windows disk and choosing the "Repair" option then go into that and run the chkdsk utility.
** EDIT **
Noticed the NO CD option. I suggest grabbing Hirens 14.0 and booting into the Mini-XP it has.
MacJunky August 30, 2011 09:46 AM
And yea, what enab says. ^^^
Connect an external optical drive and boot off that.
You do not need anything special, just a stripped down external PATA or SATA enclosure should work.
*Edit
Hehehe. :P
Enab, you and your XP.
enaberif August 30, 2011 10:07 AM
*Edit
Hehehe. :P
Have it all you want.. XP still has its places in this world to do stuff!
frontier204 August 30, 2011 10:51 AM
The checker on Linux can't do anything on a Windows partition.
Given that the laptop still knows what windows is, the second you find a way to access the partition the first thing you should do is copy anything worthwhile off of it. CHKDSK can do a lot of harm if it's run on a damaged drive.
