Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old June 27, 2012, 07:11 AM
Bungwirez's Avatar
does the job of cutting panels well enough. grinder to smooth out edges. 20 bucks with goggles.
Jobmate 36-piece Rotary Tool Kit | Canadian Tire
If you don't like funerals, don't kick sand in Ninja's face
  #22 (permalink)
Old June 29, 2012, 05:28 PM
t0m's Avatar
t0m t0m is offline
Icarus : im strongly leaning towards glass for my current case. do you have any pictures of the inside and outside of that side panel/window? it sounds sexy as hell.
Bungwirez : have you tried that one out? i actually asked about that exact model a while ago here, but the thread was lost during the joker redirect episode. i would love to hear some impressions of how it is for working on cases and plexi, and how it compares to the dremel kits (like the 34 piece dremel kit that is more than 10x the price of this one).
nothing left and nothing right
  #23 (permalink)
Old June 29, 2012, 05:35 PM
Adzsask's Avatar
Bought this one 4 years ago... used it two years to go around electrical boxes and light fixtures while drywalling, and various other odds and ends. Still going the old trooper, bought 2 spares and still have yet to have to open them.
TheToolStore.ca | Hand Tools, Woodworking Tools, Garden Tools, Power Tools
  #24 (permalink)
Old June 29, 2012, 06:13 PM
t0m's Avatar
t0m t0m is offline
thanks for the link. its still twice the cost of the one Bungwirez posted though...i spent all my money on the pc parts so i am trying to get the last bits finished up as cheap (or free) as i can
  #25 (permalink)
Old June 29, 2012, 06:21 PM
Adzsask's Avatar
comes with over 120 accessories , thats why it costs more.
  #26 (permalink)
Old June 29, 2012, 06:35 PM
mcdermot lumber seems to have better pricing than rona/home depot on plastic sheeting.
  #27 (permalink)
Old June 29, 2012, 06:37 PM
I really dislike the look of double sided sticky tape. It looks unfinished to me. Drilling out for nice flush mount socket heads looks a lot cleaner to me.
  #28 (permalink)
Old June 29, 2012, 07:53 PM
t0m's Avatar
t0m t0m is offline
thats a good point. how is this kit for metal cutting discs and other things i would want to work on my pc case? does it come with discs like these? if so how is the quantity and quality of them?
  #29 (permalink)
Old June 29, 2012, 08:03 PM
Adzsask's Avatar
Included ones are small but do the job, I just grab the larger fiberglass ones from can tire.
  #30 (permalink)
Old June 29, 2012, 10:57 PM
t0m's Avatar
t0m t0m is offline
awesome ill probably grab that one then. thanks for the advice :)
HTPC Case with Side/Top Window Closed Note Cases 0 September 15, 2010 07:04 AM
Acrylic side panel modding LC0g Cases 6 June 7, 2009 05:17 PM
CM 690 Side window Theblackmages Case Mods, Worklog & Gallery 6 February 2, 2008 08:28 PM
Looking for a P182 Window Side Panel IN CANADA Hillsdale Cases 10 December 15, 2007 07:09 PM
