Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 10, 2011, 11:51 AM
Shadowmeph's Avatar
Default My DVD reincode is Huge
I am trying to learn how to rip and convert dvds into good quality AVI files that have the same Volume as a Normal AVI , meaning that when ever I have downloaded a TV ep that is either HD or in the .mkv formate I have to really turn up the volume on my TV .
I am using TMPGEnc I mounted, loaded the ISO file and then went into preferences and in the input/output format list I selected AVI ,( I actually don't really know what to do) now I look at the left bottom side and it shows
Video: x264vfw-H264/MEPG-4 AVC codec (X264),
Audio Uncompressed PCM
what am I doing wrong that makes this DVCD go from a 4gb size to over a 11gb size?
Old July 10, 2011, 07:41 PM
you audio is uncompressed.
Old July 10, 2011, 07:57 PM
Shadowmeph's Avatar
what do I use to compress the audio?
Old July 10, 2011, 08:08 PM
TMPGEnc should compress it. Pick a compression format... I'm not sure what your choices are.
Old July 10, 2011, 08:12 PM
also, what bitrates are you setting? I'm assuming you're keeping DVD resolution?
Old July 10, 2011, 09:49 PM
MARSTG's Avatar
try Handbrake also, is easier to use and more graphical. and scales very well on multicore cpu. just what the doctor ordered for your quad.
Old July 11, 2011, 12:10 AM
supaflyx3's Avatar
i would keep it an mkv file, xvid and avi are slowly dying.
Old July 11, 2011, 12:25 AM
lowfat's Avatar
Personally I'd use handbrake. Extremely easy to use interface.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 11, 2011, 11:01 AM
MKV is just a container, like AVI. The actual compression format is still independant of the container, though there are pros and cons to using each one.
Handbrake is also, Win.
Old July 11, 2011, 12:13 PM
Shadowmeph's Avatar
I used to use handbrake but have forgotten how to use it lol I guess I will figure it out.
as for the .mkv format ,when ever I have played that format the volume is always so low compared to avi which is why I have been playing around with the avi format.
how to burn flash video to dvd that cna play on dvd player? hohohee Off Topic 0 April 22, 2010 06:35 PM
[WTB] huge pc case kyle_L Buy/Sell & Trade 17 December 23, 2009 10:57 PM
[WTB] IDE DVD-ROM or DVD burner b1lk1 Buy/Sell & Trade 9 December 10, 2008 06:38 AM
need a good dvd player that shuffles dvd of mp3s DerekOldschool HTPC Systems & Software 4 September 3, 2008 08:10 PM
