Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old June 28, 2011, 03:24 PM
Default motherboard and Components help
K first im not a computer guy,i just play some games here and there not much.I want to get a new case for my pc and i want to do what happens when i remove the motherboard and the components? will i have to reinstall the win 7? so basically i just want to know what will happen when i reinstall motherboard and the Components again.
Old June 28, 2011, 04:04 PM
As long as you aren't changing the components and install them in the same ports that you took them out of you should be able to boot like nothing happened..
If your not 100% sure of what drive is plugged in where etc.. just take a pic.
Old June 28, 2011, 04:13 PM
thank u so much
Old July 27, 2011, 04:52 PM
even if you do not plug them in the same port by accident maybe the first boot will be a tad longer but no issues there. Win 7 is pretty smooth on that.
Upgrading Core Components NickP New Builds 7 December 18, 2009 03:18 PM
New build components suggestions please Eagle Eye New Builds 10 October 23, 2008 01:57 PM
A new MoBo and my old components Flanando New Builds 7 August 14, 2008 07:47 AM
fitting PCI components on a Motherboard tom.mullie CPU's and Motherboards 2 February 9, 2008 06:07 PM
My new components keenan CPU's and Motherboards 10 August 12, 2007 11:36 AM
