Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old May 13, 2011, 09:25 AM
Dharmaboy's Avatar
Default Overclocking 2600k with P8P67 Rev3 Mobo
This is part continuation from my thread in the new builds section. I did a search for this combination and it didnt come up with anything. I know Eldonko was helping with some questions I had about overclocking.
My Specs first
  1. Intel i7 2600k
  2. P8P67 Deluxe Mobo (BIOS 1503)
  3. 8GB Corsair Vengeance (1600Mhz)
My issue is I used the auto-tune software in windows and it didn't seem to work so I thought. Every time my PC would reboot after OC'ing at 4.9Ghz, CPUZ would come back to where it was stock clocks. (I figured it was the down stepping *facepalm* )
Where do I go in AI Tweaker to change the timings so that I have a BIOS level change to ensure that my PC boots up without issues? I found that after I changed the timing in OC Tuner from stock 34 to 44, whenever my machine comes out of hibernate, it has an OC error and does a boot, shutdown, boot, shutdown and boot cycle, which finally goes into Windows.
Any guides where I can change one thing at a time, monitor it and then change something again, monitor it, bump up something somewhere, monitor it...etc. etc?
Thanks
Old May 13, 2011, 09:35 AM
Software bad mmm k :)
Use BIOS level settings for overclocking and don't go crazy like you did. Baby steps!
Old May 13, 2011, 09:46 AM
Dharmaboy's Avatar
Yeah I have just accepted the fact I will play in the BIOS. Now what do I change first?
double
just saw this from an old thread. I will post my results after this.
P67 Sandy Bridge Overclocking Guide For Beginners
Old May 13, 2011, 09:55 AM
double
Basically with the 1155 stuff. Just up the multiplier a bit at a time.
Old October 19, 2011, 07:54 PM
Was able to get my 2500k to 5GHZ using an asus board.
Old October 19, 2011, 10:50 PM
bradleyg5's Avatar
>>The Official ASUS P8P67/P8Z68 (GEN3) Series Owners Club>> - Overclock.net - Overclocking.net
New Rig - i7 2600k + P8P67 Deluxe Dharmaboy New Builds 36 May 11, 2011 08:08 PM
SLI 570 vs Crossfire HD6970 on SB 2600K+ASUS P8P67 Deluxe Delavan Video Cards 21 April 3, 2011 10:47 AM
P8P67 Deluxe and 2600K cooler? snowbound CPU's and Motherboards 7 March 29, 2011 08:55 AM
2600k Overclocking Wi-Fuzzy Overclocking, Tweaking and Benchmarking 16 March 27, 2011 06:09 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 10:20 AM
