<~----> Applying 3M Di-Noc Carbon Fiber Film - Page 3 - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
  #21 (permalink)
Old July 21, 2011, 01:41 PM
Astaroth's Avatar
How suitable would this material be for ram sinks? I think it would look real sharp on the non pointy ram sinks, but heat might be too great an issue given the nature of the material.
  #22 (permalink)
Old August 2, 2011, 04:32 AM
Mnpctech's Avatar
Youre right, It will insulate the heat sinks, and prevent them from fully dissipating the heat
  #23 (permalink)
Old October 24, 2011, 05:25 AM
Inspired by some of the great Di-Noc idea's I've seen around, I set about doing one of my own:
This is the motherboard tray of my new Thermaltake Level 10 GT "Snow Edition". The tray is NOT removable, so some drilling was required to get the rivets out and free the tray. I then applied white Di-Noc with a heat gun and a lot of patience and re-assembled. The white goes nicely with the ample white of the case.
Personally I love the look and can't wait to start moving my hardware into this new case.
  #24 (permalink)
Old October 25, 2011, 01:44 PM
Supergrover's Avatar
Finally got around to doing mine, one panel on the mouse needs to be reapplied but wanted to wait since I will be using the scrape from my KB. Did not want to waste the 12 inch I have left. Turned out alright though, more you work with it the easier it is IMO. Best way I found towards the end was tones of heat and 2 ppl, makes stretching it so much easier. Keyboard turned out better than the mouse but again learned more as I went.
R.I.P.
  #25 (permalink)
Old October 29, 2011, 08:29 AM
@ Supergrover Keyboard looks great!
Did the side door of my Level 10 GT in black. I love the look.
Before --> During --> After ;)
  #26 (permalink)
Old November 1, 2011, 01:06 AM
Thank You.
Thats turning out nice, I was amazed by the amount of stretch you get with this product.
I plan to do some more with this product but will have to wait till after xmas for some room in the shop.
R.I.P.
  #27 (permalink)
Old November 24, 2011, 04:27 AM
Mnpctech's Avatar
I applied 3M DI-NOC Black carbon fiber film onto the TUF shield on the ASUS Sabertooth P67 Motherboard
You can also apply it onto Power Supplies, Cases, Monitor, Keyboard, Mouse, Drive faces, Headphones, Bezel, Fan controllers, Toggle switchs etc. 3M Di-Noc carbon fiber film
  #28 (permalink)
Old December 5, 2011, 05:27 AM
Mnpctech's Avatar
I just finished the Arc for Fractal-Design's booth at 2012 CES with 3M Di-Noc Carbon Fiber sheet applied to the Asus Sabertooth P67 and Power Supply.
  #29 (permalink)
Old December 11, 2011, 07:25 AM
How would this stuff work on the top of a case like the 650D? And does it come in Red?
  #30 (permalink)
Old December 11, 2011, 08:19 AM
You would just have to apply then cut out the grill, shouldnt be too hard.
This place has more options for patterns and "colors", sadly no red.
3M DI-NOC Carbon Fiber Vinyl | Carbon Fiber Gear
R.I.P.
Create Carbon Fiber Mouse with Spray Paint Mnpctech Guides & How-to's 3 May 12, 2011 08:44 PM
crash when applying overclocking settings **FIXED** BrianHanna Overclocking, Tweaking and Benchmarking 3 November 4, 2010 03:41 PM
Painting MX518 Logitech Mouse with "Carbon Fiber" Effect Mnpctech Guides & How-to's 18 November 11, 2009 03:11 PM
Applying online. muse108dc Off Topic 7 November 11, 2009 08:41 AM
Carbon Fiber Sticker enaberif Off Topic 1 February 2, 2009 05:44 PM
