Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old July 8, 2011, 09:37 AM
Mnpctech's Avatar
Yes! Here is video tutorial I made
YouTube - ‪3M Di-Noc Carbon Fiber Mouse & PC Fan Grill Mods, Mnpctech.com‬‏
Here are the photos of the 120mm acrylic honeycomb fan grill with 3M Di-Noc Carbon Fiber Material from the guide in the video I posted earlier
Old July 8, 2011, 03:29 PM
Mnpctech's Avatar
modder, kier sent me this photo today, evga classfied ek chipset waterblock with 3M Di-Noc carbon fiber applied on top
Old July 8, 2011, 04:36 PM
PerryC's Avatar
The fan grills look sweet all done up like that.
Old July 9, 2011, 04:44 AM
Mnpctech's Avatar
I agree Perry, I've had people ask if you can clear coat the 3M carbon fiber material, So Last night I applied Automotive Enamel Gloss Clear coat over the honeycomb fan grill with the di-noc carbon fiber. Here is the results. I'm curious to see what a Matte Finish Clear would look like as well.
Old July 9, 2011, 01:32 PM
PerryC's Avatar
Its too bad this doesn't fit with what I am toying at doing with my case....I really like the look of that fan grill.
Old July 16, 2011, 05:33 AM
Mnpctech's Avatar
I was happy to see that the clear coat worked
Old July 16, 2011, 09:18 AM
Mnpctech's Avatar
Richard sent me this photo of his Asus Rampage III Extreme with 3M carbon fiber material applied and It fits the theme nicely!
Old July 18, 2011, 07:11 AM
Trial Member
Default 3M Scotchprint 1080 Series
[quote=Mnpctech;531195]
Great Video. However, the material you are using is NOT 3M DI Noc material - not sure why you are representing this product incorrectly. The material you are selling is 3M Scotchprint 1080 Series Black Carbon Fiber - CF12. We install both products and the backing material is entirely different. Also both product have a different look - the Di Noc is a dry carbon look with a true weave where as the scotchprint has alittle more gloss to it. Hope this helps.
  #19 (permalink)
Old July 18, 2011, 06:33 PM
martin_metal_88's Avatar
I would love to do it a lot on my Samsung galaxy S, but I don't know if it will work since the Galaxy is not flat on the back :(
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #20 (permalink)
Old July 19, 2011, 08:36 AM
PerryC's Avatar
You should be able to heat it up and stretch it...sort of the the same thing he does with the mouse in the video.
Create Carbon Fiber Mouse with Spray Paint Mnpctech Guides & How-to's 3 May 12, 2011 08:44 PM
crash when applying overclocking settings **FIXED** BrianHanna Overclocking, Tweaking and Benchmarking 3 November 4, 2010 03:41 PM
Painting MX518 Logitech Mouse with "Carbon Fiber" Effect Mnpctech Guides & How-to's 18 November 11, 2009 03:11 PM
Applying online. muse108dc Off Topic 7 November 11, 2009 08:41 AM
Carbon Fiber Sticker enaberif Off Topic 1 February 2, 2009 05:44 PM
