Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old March 23, 2011, 06:23 AM
Default Good antistatic mat ?
Hello,
I am looking for a good antistatic mat.. any suggestions ?
Thanks.
Old March 23, 2011, 06:26 AM
francisw19's Avatar
I've used one similar to this for quite some time...it's served me well.
StarTech Desktop Anti-Static Mat, 24in x 26in at Memory Express Computers
Old March 23, 2011, 07:27 AM
it is need to have a wrist with that ?
Old March 23, 2011, 07:34 AM
Lpfan4ever's Avatar
Anti static anything..lol. I've built computers on carpet without issue (though, not recommended), just keep touching a bare metal part on your case.
Originally Posted by encorp
Code:
<firebane> slightly used
Old March 23, 2011, 02:51 PM
Just use that soft backing they ship most asus motherboards with, its like foam, but red/pink
Old March 23, 2011, 05:32 PM
I believe the wrist strap is more important than the anti static mat, but that said I only use the wrist strap and not the mat. If you don't have a grounded strap (either on your wrist, ankle, or shoe), then remember that you can build up a charge moving around so you have to touch your anti static mat or whatever it is electrically connected to so you don't zap your components.
Instead I ground my case while working on PCs, and I always have an anti static bag ready for a component if I'm taking it out of the case. Essentially my computer components only ever touch the inside of the anti-static bag, my fingers (while I'm wearing a wrist strap), and the computer case / components inside the computer case which is grounded either by having the PC's PSU plugged in but turned off, or through the odd setup through a butchered AT power supply as I pictured below.
Figure: Oddball grounding scheme that goes wall -> cheap PSU that's turned off -> alligator clip -> case of computer I'm working on
mouse pad/mat... do you need one? CTA Peripherals 15 March 4, 2011 08:08 PM
what is a good Media player for a good price or any suggestions Shadowmeph HTPC Systems & Software 4 December 19, 2009 10:27 PM
I think this is good timidestemu New Builds 4 August 6, 2009 07:47 PM
Razer Launches Mobile Gaming Mouse and Mouse Mat FiXT Press Releases & Tech News 2 July 24, 2009 09:11 AM
Hole in antistatic bag SuperFriedFish Troubleshooting 11 August 5, 2008 06:06 PM
