Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old February 14, 2011, 03:33 AM
KaptCrunch's Avatar
Default check your front panel usb ports with multimeter
MB manual usb pinout. just have a multimeter to verify connections on case socket to MB usb header.
NOTE: power(5v) = vcc
and check only cable end (MB header plug) to socket with diode check setting on meter(zero means 100% connected, some meters beep) or (OHMs) resistance mode zero means 100% connected or continuity
Front panel header rock_meg Troubleshooting 12 January 18, 2011 08:08 PM
Front Panel advice Graysccale Audio 4 March 6, 2010 02:55 PM
Front panel ground? martin_metal_88 Troubleshooting 0 May 31, 2009 06:00 PM
cant plug in front panel usb and firewire? go flames go New Builds 11 April 8, 2009 02:16 PM
stacker 830 front usb ports problem... CraigHf Troubleshooting 4 April 13, 2008 07:07 PM
