How To: DVD Drive Window Mod You’ve seen the Hard drives with windows, but how about a DVD drive? It’s easy to do and fun to watch! Make DVD & CD-ROM Drive Window Mod. | Case Mod Blog http://www.mnpctech.3dpixelnet.com/p...od_guide9t.jpg |
Great, wow. I might try this. Specially If I destroy the drive, it is not that expensive to replace.... I would like to buy acrylic from you, tape and cutting disk, but since you are in the USA, not efficient to do.... Altough, if I dind enough stuff, it might work |
I did a windowed hdd mod back in the day, mounted upright and facing the side window looked awesome but I am wondering why I would do a dvd drive. If you had a accrillic case this would look sweet but in a standard case the dvd drive is hidden mostly so IMO that is a huge drawback. Still a very cool mod though though at least you dont have to worry about contaminates as you would for a hdd. Love the cd choice in the tut.:thumb: |
There is a link to another mod for the top of the case in there. It is to correct what you described. |
Agree, pointless if you cant see it...lol.. I'll be posting a guide on adding a window to the top of your case next :thumb: btw: Some people asked if the LEDS would effect the disc reader (eye) performance. No worries the LEDs project above the DVD and reader is on different frequency. |
I imagine that with the LED's and a disc running it would look pretty cool. Ohhh shiny! |
About the led, do you have a tutorial how to make them, or at least, a place to buy them ? |
Your links not working! |
| All times are GMT -7. The time now is 06:34 AM. |
