Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old November 7, 2010, 10:31 PM
Trial Member
Thumbs down xbox 360 trouble
Hey guys,
Not sure where else to post this. I took apart my little brother's xbox 360 not too long ago to try and fix the red ring using pennies. I tried the towel trick and it didn't work.
I powered it up and the middle light was on, and green, but none of the lights on the outer ring were on. I took it apart again and reassembled with the same result. Any ideas where I went wrong? I suppose at the very least I don't have the red lights any more.
Thanks for the help.
Mal
Old November 7, 2010, 10:40 PM
Jackquelegs's Avatar
The center light is on when the Xbox starts and does the POST check. If the light is stuck, that means the system can't boot. I'm pretty sure the act of fixing the xbox had bricked it.
Iapetos
Zephyranthes
Old November 7, 2010, 11:38 PM
KaptCrunch's Avatar
need to reflow gpu
Old November 8, 2010, 12:26 AM
dustin1706's Avatar
The penny trick and towel trick are kinda sketchy IMO. I scoured the net for a few hours before deciding how best to fix mine.
I pulled the heatsinks off, covered the sensitive parts of the board with foil as per youtube vids, and heated up the area around the chips slowly with a heat gun. Then I ended up getting some m5 x 12 (8) machine screws and some nylon washers and using them to attach the heat sinks more firmly to the mobo.
It's been running for about 6 months since with no issues, and it is a first batch xbox from before Christmas 2005.
Old November 9, 2010, 05:07 PM
Deeival's Avatar
This is by far the smartest way of going about this. I fixed 2 xboxs this way and it cost about $5. Both of them still running fine.
Old November 9, 2010, 06:44 PM
JD JD is offline
Worked for a couple weeks, but now it won't get past the RROD. I just gave up with that XBOX though and got a Jasper (this happened a while back now).
Old November 17, 2010, 01:22 AM
Ctech's Avatar
Restricted Poster
If the XBOX has HDMI - no video cable plugged in
If the XBOX does NOT have HDMI or video cable is plugged in - board is still dead and has to be reflowed and X-clamp replacement
Xbox 360 Laptop Butkick Mobile Computing 8 June 4, 2010 05:23 PM
[FS] Xbox 360 with extras FrankyG Buy/Sell & Trade 4 March 28, 2010 05:02 PM
XBOX 360 or PS3 trayton Gaming 51 February 23, 2010 11:08 AM
Watercooling my xbox 360 Navi Water Cooling 9 February 4, 2010 11:00 AM
PS3 vs XBox 360 sswilson Gaming 72 May 24, 2009 03:37 PM
