Hey guys this is a simple guide on how to remove the 1.087V voltage cap on your gtx 460 allowing you to push the voltage all the way to 1.212V to help achieve the overclock you want. I just did it using this exact method so i thought i would share.
First off i assembled a package of software you will need.
GPU Z 4.7
nvFlash 5.95
Nibitor 5.8
Download Here
1.
Acquire your bios with GPUz and it's save to file feature:
2. Open the bios file with Nibitor:
go to Tools> fermi Voltage and select the max voltage you want from drop down.
Hit apply and save the new bios under C:\ as mod.rom
3. Copy the contents of nvflash folder to C:\
4. open cmd with admin privileges
5. type cd / this will take you to root of c directory
6. type nvflash -b backup.rom (this backs up your original firmware)
7.Type nvflash -5 -6 mod.rom (this flashes the bios)
8. it will ask you if you are sure press y to continue
9. DONE enjoy your 1.212 voltage cap
I DO NOT TAKE RESPONSIBILITY FOR YOUR ACTIONS.... USE THIS GUIDE AT YOUR OWN RISK
