Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 21, 2010, 03:07 PM
Default Re-routing optical drive eject button
I'd really like to stealth out my two optical drives and have the eject buttons all in one 5.25" bay. I already bought LED illuminated momentary switches, but I'm cautious about opening up the drive and doing some soldering.
Can anybody give me detailed instructions on how to do this or link me to a thread about it.
I'm not worried about voiding the warranty or anything like that.
Old August 21, 2010, 03:44 PM
Perineum's Avatar
It's just a contact switch like any reset or power switch on the case. Unsolder the switch, hang some wires off it at the length you want to go then put the new switch where you want it.
Old August 21, 2010, 03:46 PM
Figure out the contacts on the PCBs where the current switches are connected, and just solder the new switches to those points. You don't even need to disconnect the old switches.
Old August 21, 2010, 03:56 PM
MacJunky's Avatar
Make sure you add a connector in the cable somewhere though so you can easily remove the drives.
Beginner Builder, Optical Drive Questions Charmster Storage 3 June 17, 2010 10:32 PM
Mounting a 3.5" HDD into a 5.25 Optical drive bay using scews Zippoh Storage 7 January 5, 2009 07:05 PM
Nige's 939/SODIMM/psu/optical drive sale **SODIMM memory added 09/24/08** nige Buy/Sell & Trade 15 October 24, 2008 07:17 AM
Mobo, CPU, Optical drive, HD, and more NEW! tgraszat14 Buy/Sell & Trade 2 June 10, 2008 03:56 AM
