<~----> Opening a GTX 470 GPU - Hardware Canucks
Go Back   Hardware Canucks > PC BUILDERS & TWEAKERS CORNER > Guides & How-to's
Old August 20, 2010, 08:22 PM
Default Opening a GTX 470 GPU
FIRST POST YAY!!!
Anyway... I was wondering how you could open a gtx 470 video card. Specifically the PALiT GTX 470. I'd like to paint the fans blue to match the color scheme of my build.
Old August 20, 2010, 08:46 PM
Unscrew the screws on the back of the card, remove the heatsink, etc. It's not a particularly difficult thing to do. However, painting fans in general is not a very good idea. I would suggest that you take a look at this Galaxy GTX 470, since it already has a blue fan: Newegg.ca - Galaxy 70XKH3HS3CUB GeForce GTX 470 &#40;Fermi&#41; 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Old August 20, 2010, 08:50 PM
Thanks for the quick reply... lets be honest though. The galaxy card is really ugly. And I'm looking for a graphics card with great cooling so that I can overclock.
The gigabyte super oc 470 is the next on my list, but that sells for like $470
Old August 20, 2010, 09:04 PM
Caldezar's Avatar
Hmmm.... I don't think Palit supports mods to the card, so be aware that this will likely void your warranty.
Old August 20, 2010, 10:18 PM
Realityshift's Avatar
I agree with cald, if you pull that fan out you have to deal with taking it appart and puting it back together as well as possibly putting it out of ballance if you dont spray the paint on perfectly evenly.. Id try and find a model that other then this one that has the colors you want or deal with the colors available rather then mod a fan.
The Builders Hammer
Old August 21, 2010, 06:56 AM
Thanks for the advice guys... I'll take it into consideration. I think I'll just save up a little more and get the Gigabyte SOC that I really want.
Old August 30, 2010, 12:36 AM
Jokester's Avatar
If you do want to remove the heatsink, heres how:
YouTube - CMP: EVGA GTX 470 Disassembly
Techead in mind, body and soul
Lian Dream: i7 2600k @ 5.1Ghz, Asus Maximus IV Gene-z, MSI N580GTX Twin Frozr II,8GB 2x4GB Mushkin Ridgeback, Crucial M4 128GB x2, Plextor PX-755SA, Seasonic 750, Lian-li
HTPC: E5300@3.6ghz, Asus P5Q Pro Turbo, Gigabyte 7600GT, Mushkin redline 1GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, PC P&C 510, Silverstone LC16m
Old September 1, 2010, 02:43 PM
Kommie986's Avatar
Originally Posted by ZombieAttack27 View Post
FIRST POST YAY!!!
In a standard case, I don't think you can see the fan of your video card. And also, the Gigabyte SOC GTX 470 is only ~$400 CAD on NewEgg.
Old September 17, 2010, 05:38 PM
paying 400 bucks for a 470 is pure madness IMO
Review Units FS. GTX 650 Ti Boosts Galore! All UNDER $130!! SKYMTL Buy/Sell & Trade 711 Yesterday 05:45 PM
Koolance Releases GTX 470 & GTX 480 Full Coverage Waterblocks FiXT Press Releases & Tech News 7 April 9, 2010 07:34 PM
PNY Technologies Unveils GeForce GTX 470 & GTX 480 FiXT Press Releases & Tech News 3 March 29, 2010 03:15 PM
NVIDIA Clarifies Official GTX 480 and GTX 470 Launch Date matsta31 Press Releases & Tech News 76 March 9, 2010 01:07 AM
